A forward-backward stochastic analysis of diffusion flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2019
Pierre del Moral
S.S. Singh
  • Fonction : Auteur
  • PersonId : 862665
We present forward-backward stochastic semigroup formulae to analyse the difference of diffusion flows driven by different drift and diffusion functions. These formulae are expressed in terms of tangent and Hessian processes and can be interpreted as an extension of the Aleeksev-Gröbner lemma to diffusion flows. We present some natural spectral conditions that allows to derive in a direct way a series of uniform estimates with respect to the time horizon. We illustrate the impact of these results in the context of diffusion perturbation theory, interacting diffusions and discrete time approximations.
forward-backward-diffusions.pdf (399.42 Ko) Télécharger le fichier
hal-02161914 , version 1 (21-06-2019)
hal-02161914 , version 2 (09-07-2019)
hal-02161914 , version 3 (21-10-2019)
hal-02161914 , version 4 (22-06-2020)
hal-02161914 , version 5 (30-04-2021)
Pierre del Moral, S.S. Singh. A forward-backward stochastic analysis of diffusion flows. [Research Report] INRIA. 2019. ⟨hal-02161914v1⟩
208 Consultations
440 Téléchargements
