Conference papers
The MPFI Library: Towards IEEE 1788-2015 Compliance
Nathalie Revol 1
1 ARIC - Arithmetic and Computing
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme
Abstract : The IEEE 1788-2015 has standardized interval arithmetic. However, few libraries for interval arithmetic are compliant with this standard. The main features of the IEEE 1788-2015 standard are detailed, namely the structure into 4 levels, the possibility to accomodate a new mathematical theory of interval arithmetic through the notion of flavor, and the mechanism of decoration for handling exceptions. These features were not present in the libraries developed prior to the elaboration of the standard. MPFI is such a library: it is a C library, based on MPFR, for arbitrary precision interval arithmetic. MPFI is not (yet) compliant with the IEEE 1788-2015 standard for interval arithmetic: the planned modifications are presented. Some considerations about performance and HPC on interval computations based on this standard, or on MPFI, conclude the paper.
Document type :
Conference papers
Complete list of metadata
Cited literature [29 references]  Display  Hide  Download
https://hal.inria.fr/hal-02162346
Contributor : Nathalie Revol Connect in order to contact the contributor
Submitted on : Friday, June 21, 2019 - 4:41:47 PM
Last modification on : Monday, May 16, 2022 - 4:58:02 PM
File
NRevol-PPAM2019.pdf
Identifiers
Collections
Citation
Nathalie Revol. The MPFI Library: Towards IEEE 1788-2015 Compliance. PPAM 2019 - 13th International Conference on Parallel Processing and Applied Mathematics, Sep 2019, Bialystok, Poland. pp.353-363, ⟨10.1007/978-3-030-43222-5_31⟩. ⟨hal-02162346⟩
Share
Metrics
Record views
139
Files downloads
195
