Abstract : This note contains some proofs for the paper "Discretization of Homogeneous Systems Using Euler Method with a State-Dependent Step" of the same authors.
Denis Efimov, Andrey Polyakov, Alexander Aleksandrov. Proofs for "Discretization of Homogeneous Systems Using Euler Method with a State-Dependent Step". 2019. ⟨hal-02164050⟩
