Controllability of Localized Quantum States on Infinite Graphs through Bilinear Control Fields - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Control Année : 2019
Kaïs Ammari
Alessandro Duca
In this work, we consider the bilinear Schr\"odinger equation (BSE) $i\partial_t\psi=-\Delta\psi+u(t)B\psi$ in the Hilbert space $L^2(\mathscr{G},\mathbb{C})$ with $\mathscr{G}$ an infinite graph. The Laplacian $-\Delta$ is equipped with self-adjoint boundary conditions, $B$ is a bounded symmetric operator and $u\in L^2((0,T),\mathbb{R})$ with $T>0$. We study the well-posedness of the (BSE) in suitable subspaces of $D(|\Delta|^{3/2})$ preserved by the dynamics despite the dispersive behaviour of the equation. In such spaces, we study the global exact controllability and the "energetic controllability". We provide examples involving for instance infinite tadpole graphs.
grafi_ijc.pdf (441.46 Ko) Télécharger le fichier
hal-02164419 , version 1 (25-06-2019)
hal-02164419 , version 2 (16-07-2020)
Kaïs Ammari, Alessandro Duca. Controllability of Localized Quantum States on Infinite Graphs through Bilinear Control Fields. International Journal of Control, 2019, 94 (7), pp.1824-1837. ⟨10.1080/00207179.2019.1680868⟩. ⟨hal-02164419v2⟩
133 Consultations
236 Téléchargements
