A mathematical formulation and complexity considerations for the blocks relocation problem, European Journal of Operational Research, vol.219, issue.1, pp.96-104, 2012. ,
Crane scheduling for opportunistic remarshaling of containers in an automated stacking yard, Flexible Services and Manufacturing Journal, vol.27, issue.2, pp.331-349, 2015. ,
A tree search procedure for the container relocation problem, Operations Research, vol.39, issue.2, pp.299-309, 2012. ,
Pre-marshaling inbound containers utilizing truck arrival information with uncertainty, 2016. ,
Heuristic algorithms for the container pre-marshaling problems, Computers and Industrial Engineering, vol.62, issue.1, pp.13-20, 2012. ,
Container Relocation Problem with time window for container departure, European Journal of Operational Research, vol.252, issue.3, pp.1031-1039, 2016. ,
Target-guided algorithms for the container pre-marshaling problem, Omega, vol.53, pp.67-77, 2015. ,
The impact of truck arrival information on container terminal rehandling, Transportation Research Part E, vol.46, issue.3, pp.327-343, 2010. ,
