Strategies for customized shipbuilding with different customer order decoupling points. Proceedings of the Institution of Mechanical Engineers, Part M: Journal of Engineering for the Maritime Environment, vol.228, issue.4, pp.362-372, 2014. ,
Exploring the archetypes of engineer-to-order: an empirical analysis, International Journal of Operations & Production Management, vol.36, issue.3, pp.242-264, 2016. ,
A new set of principles for pursuing the lean ideal in engineer-to-order manufacturers, Procedia CIRP, vol.17, pp.571-576, 2014. ,
The Toyota product development system, vol.13533, 2006. ,
DOI : 10.4324/9781482293746
The irrational side of change management, McKinsey Quarterly, vol.2, issue.10, pp.100-109, 2009. ,
Applicability of lean principles and practices in industrialized housing production, Construction management and Economics, vol.26, issue.10, pp.1091-1100, 2008. ,
Theory building from cases: opportunities and challenges, Academy of Management journal, vol.50, issue.1, pp.25-32, 2007. ,
DOI : 10.5465/amj.2007.24160888
