Implementation of modeling and simulation in semiconductor wafer fabrication with time constraints between wet etch and furnace operations, IEEE Transactions on Semiconductor Manufacturing, vol.13, issue.3, pp.273-277, 2000. ,
Capacity planning for semiconductor wafer fabrication with time constraints between operations, Proceedings of the 31st Conference on Winter Simulation, pp.880-887, 1999. ,
DOI : 10.1145/324138.324545
Influence of capacity and time-constrained intermediate storage in two-stage food production systems, International Journal of Production Research, vol.45, issue.13, pp.2955-2973, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00512926
A decomposition approach for the scheduling of a steel plant production, Computers & Chemical Engineering, vol.25, pp.1647-1660, 2001. ,
A hybrid two-stage flow shop with limited waiting time constraints, Computer and Industrial Engineering, vol.44, pp.409-424, 2003. ,
Dynamic production control in a serial line with process queue time constraint, International Journal of Production Research, vol.48, issue.13, pp.3823-3843, 2010. ,
Dynamic production control in parallel processing systems under process queue time constraints, Computers & Industrial Engineering, vol.63, issue.1, pp.192-203, 2012. ,
Multiple product admission control in semiconductor manufacturing systems with process queue time (PQT) constraints, Computers & Industrial Engineering, vol.99, pp.347-363, 2016. ,
Dynamic Programming, Courier, 2003. ,
Decomposition-based classified ant colony optimization algorithm for scheduling semiconductor wafer fabrication system, Computers & Industrial Engineering, vol.62, issue.1, pp.141-151, 2012. ,
Production control policy for tandem workstations with constant service times and queue time constraints, International Journal of Production Research, vol.54, issue.21, pp.6302-6316, 2016. ,
Scheduling wafer lots on diffusion machines in a semiconductor wafer fabrication facility, IEEE Transactions on Semiconductor Manufacturing, vol.23, issue.2, pp.246-254, 2010. ,
Combinatorial Benders' cuts for mixed-integer linear programming, Operations Research, vol.54, issue.4, pp.756-766, 2006. ,
A combinatorial benders' cuts algorithm for the quayside operation problem at container terminals, Transportation Research Part E: Logistics and Transportation Review, vol.48, issue.1, pp.266-275, 2012. ,
Combinatorial Benders cuts for assembly line balancing problems with setups, European Journal of Operational Research, vol.259, issue.2, pp.527-537, 2017. ,
IIS branch-and-cut for joint chance-constrained stochastic programs and application to optimal vaccine allocation, European Journal of Operational research, vol.207, issue.1, pp.290-296, 2010. ,
