3D Surface Reconstruction from Voxel-based Lidar Data - Archive ouverte HAL Access content directly
Conference Papers Year :
(1, 2) , (1) , (1)
1
2
To achieve fully autonomous navigation, vehicles need to compute an accurate model of their direct surrounding. In this paper, a 3D surface reconstruction algorithm from heterogeneous density 3D data is presented. The proposed method is based on a TSDF voxel-based representation, where an adaptive neighborhood kernel sourced on a Gaussian confidence evaluation is introduced. This enables to keep a good trade-off between the density of the reconstructed mesh and its accuracy. Experimental evaluations carried on both synthetic (CARLA) and real (KITTI) 3D data show a good performance compared to a state of the art method used for surface reconstruction.
Dates and versions
hal-02165672 , version 1 (26-06-2019)
Identifiers
Cite
Luis Roldão, Raoul de Charette, Anne Verroust-Blondet. 3D Surface Reconstruction from Voxel-based Lidar Data. ITSC 2019 - IEEE Intelligent Transportation Systems Conference, Oct 2019, Auckland, New Zealand. ⟨hal-02165672⟩
Collections
INRIA INRIA2
92 View
0 Download
Share
