How to stop data centres from gobbling up the world's electricity, Nature, vol.561, issue.7722, pp.163-166, 2018. ,
Modeling data center building blocks for energy-efficiency and thermal simulations," in Energy-Efficient Data Centers, vol.8343, pp.66-82, 2014. ,
Methodology of measurement for energy consumption of applications, Tech. Rep, 2010. ,
Runtime power usage estimation of hpc servers for various classes of real-life applications, Future Generation Computer Systems, vol.36, pp.299-310, 2014. ,
A methodology for full-system power modeling in heterogeneous data centers, Proceedings of the 9th International Conference on Utility and Cloud Computing, ser. UCC '16, pp.20-29, 2016. ,
Potential effects on server power metering and modeling, Wireless Networks, pp.1-8, 2018. ,
DOI : 10.1007/s11276-018-1882-1
URL : https://hal.archives-ouvertes.fr/hal-01869705
Variation among processors under turbo boost in hpc systems, Proceedings of the 2016 International Conference on Supercomputing, ser. ICS '16, vol.6, pp.1-6, 2016. ,
An empirical survey of performance and energy efficiency variation on intel processors, Proceedings of the 5th International Workshop on Energy Efficient Supercomputing, ser. E2SC'17, vol.9, pp.1-9, 2017. ,
Evaluating the effectiveness of model-based power characterization, USENIX Annual Technical Conf, vol.20, 2011. ,
Your cluster is not power homogeneous: Take care when designing green schedulers, 2013 International Green Computing Conference Proceedings, pp.1-10, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00870637
Variations in cpu power consumption, Proceedings of the 7th ACM/SPEC on International Conference on Performance Engineering, ser. ICPE '16, pp.147-158, 2016. ,
Varius: A model of process variation and resulting timing errors for microarchitects, IEEE Transactions on Semiconductor Manufacturing, vol.21, issue.1, pp.3-13, 2008. ,
Comparing server energy use and efficiency using small sample sizes, 2014. ,
Demystifying energy consumption in grids and clouds, International Conference on Green Computing, pp.335-342, 2010. ,
URL : https://hal.archives-ouvertes.fr/ensl-00527642
The unexpected impact of raising data center temperatures, Tech. Rep, 2011. ,
Thermal analysis of high end servers based on development of detail modeland experiments, The university of texas at Arlington, 2012. ,
Accurate characterization of the variability in power consumption in modern mobile processors, Proceedings of the 2012 USENIX Conference on Power-Aware Computing and Systems, ser. HotPower'12, pp.8-8, 2012. ,
The design and development of the server efficiency rating tool (sert), Proceedings of the 2Nd ,
, ACM/SPEC International Conference on Performance Engineering, ser. ICPE '11, pp.145-150, 2011.
Etude de l'influence des aspects thermiques sur la consommation et l'efficacité energétique des serveurs, SFT 2018 -26ème Congrès Français de Thermique, pp.1-8, 2018. ,
Diagnosing performance variations in hpc applications using machine learning, High Performance Computing, pp.355-373, 2017. ,
System noise revisited: Enabling application scalability and reproducibility with smt, 2016 IEEE International Parallel and Distributed Processing Symposium (IPDPS), pp.596-607, 2016. ,
Data center power equipment thermal guidelines and best practices whitepaper, ASHRAE, Tech. Rep, 2016. ,
The technical details behind intel's 7 watt ivy bridge cpus, 2013. ,
Temperature variation characterization and thermal management of multicore architectures, IEEE Micro, vol.29, issue.1, pp.116-126, 2009. ,
Energy impact of increased server inlet temperature, APC white paper, vol.138, 2009. ,
Intel now packs 100 million transistors in each square millimeter -ieee spectrum, 2017. ,
Thermal interface materials: Historical perspective, status, and future directions, Proceedings of the IEEE, vol.94, issue.8, pp.1571-1586, 2006. ,
The need for a full-chip and package thermal model for thermally optimized ic designs, Proceedings of the 2005 International Symposium on Low Power Electronics and Design, ser. ISLPED '05, pp.245-250, 2005. ,
Material technology for environmentally micro-electronic packagingl perspective, status, and future directions, Intel Technology Journal, 2006. ,
Leakage current: Moore's law meets static power, Computer, vol.36, issue.12, pp.68-75, 2003. ,
Low power architecture design and compilation techniques for high-performance processors, Proceedings of COMPCON '94, pp.489-498, 1994. ,
45-year CPU evolution: one law and two equations, Second Workshop on Pioneering Processor Paradigms, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01719766
Intrinsic leakage in low power deep submicron cmos ics, Proceedings International Test Conference, pp.146-155, 1997. ,
Low-power digital design, Proceedings of 1994 IEEE Symposium on Low Power Electronics, pp.8-11, 1994. ,
A static power model for architects, Proceedings 33rd Annual IEEE/ACM International Symposium on Microarchitecture. MICRO-33, pp.191-201, 2000. ,
Cramming more components onto integrated circuits, Proceedings of the IEEE, vol.86, issue.1, pp.82-85, 1998. ,
Design of ion-implanted mosfet's with very small physical dimensions, IEEE Journal of Solid-State Circuits, vol.9, issue.5, pp.256-268, 1974. ,
Alpha-power law mosfet model and its applications to cmos inverter delay and other formulas, IEEE Journal of Solid-State Circuits, vol.25, issue.2, pp.584-594, 1990. ,
Theoretical and practical limits of dynamic voltage scaling, Proceedings of the 41st Annual Design Automation Conference, ser. DAC '04, pp.868-873, 2004. ,
A methodology for modeling dynamic and static power consumption for multicore processors, 2016 IEEE International Parallel and Distributed Processing Symposium (IPDPS), pp.273-282, 2016. ,
Ubuntu manpage: cpuburn, burnbx, burnk6, burnk7, burnmmx, burnp5, burnp6 -a collection, 2011. ,
2016) lm sensors -archwiki ,
, , 2009.
