Link label prediction in signed social networks, IJCAI, pp.2591-2597, 2013. ,
Learning sparse metrics, one feature 680 at a time, NIPS 2015 Workshop on Feature Extraction: Modern Questions and Challenges, 2015. ,
Concentration inequalities for sampling without replacement, Bernoulli, vol.21, pp.1361-1385, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01216652
Robustness and Generalization for Metric Learn-685 ing, Neurocomputing, vol.151, pp.259-267, 2015. ,
DOI : 10.1016/j.neucom.2014.09.044
URL : http://arxiv.org/pdf/1209.1086
Similarity Learning for Provably Accurate Sparse Linear Classification, pp.1871-1878, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00708401
Metric Learning, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01121733
Learning a Distance Metric by Empirical Loss Minimization, pp.1186-1191, 2011. ,
Manifold Adaptive Experimental Design for Text Catego-695 rization, IEEE Transactions on Knowledge and Data Engineering, vol.24, pp.707-719, 2012. ,
Generalization Bounds for Metric and Similarity Learning, 2012. ,
DOI : 10.1007/s10994-015-5499-7
URL : https://link.springer.com/content/pdf/10.1007%2Fs10994-015-5499-7.pdf
, ECML/PKDD, pp.283-298, 2012.
An empirical evaluation of supervised learning in high dimensions, pp.96-103, 2008. ,
LIBSVM : a library for support vector machines, ACM Transactions on Intelligent Systems and Technology, vol.2, pp.27-27, 2011. ,
Train-705 ing and Testing Low-degree Polynomial Data Mappings via Linear SVM, Journal of Machine Learning Research, vol.11, pp.1471-1490, 2010. ,
An online algorithm for large scale image similarity learning, NIPS, pp.306-314, 2009. ,
Large-scale behavioral targeting, p.710, 2009. ,
DOI : 10.1145/1557019.1557048
URL : http://www.cs.berkeley.edu/~jfc/papers/09/KDD09.pdf
Coresets, sparse greedy approximation, and the FrankWolfe algorithm, ACM Transactions on Algorithms, vol.6, pp.1-30, 2010. ,
Scaling-up Empirical Risk Minimization: Optimization of Incomplete U-statistics, Journal of Machine Learning 715 Research, vol.17, pp.1-36, 2016. ,
Ranking and Empirical Minimization of U-statistics, Annals of Statistics, vol.36, pp.844-874, 2008. ,
Information-theoretic metric learning, pp.209-216, 2007. ,
DOI : 10.1145/1273496.1273523
LIBLIN-EAR: A Library for Large Linear Classification, Journal of Machine Learning Research, vol.9, pp.1871-1874, 2008. ,
A Mathematical Introduction to Compressive Sensing, 2013. ,
Experiments with random projections for machine learning, pp.517-522, 2003. ,
An algorithm for quadratic programming, Naval Research Logistics Quarterly, vol.3, pp.95-110, 1956. ,
New Analysis and Results for the Conditional 730, 2013. ,
, Gradient Method
SOML: Sparse Online Metric Learning with Application to Image Retrieval, pp.1206-1212, 2014. ,
Neighbourhood 735 Components Analysis, NIPS, pp.513-520, 2004. ,
Some comments on Wolfe's away step, Mathematical Programming, vol.35, pp.110-119, 1986. ,
Is that you? Metric learning approaches for face identification, pp.498-505, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00439290
Guaranteed Classification via Regularized Similarity Learning, Neural Computation, vol.26, pp.497-522, 2014. ,
DOI : 10.1162/neco_a_00556
URL : http://arxiv.org/pdf/1306.3108
, , 2004.
A Class of Statistics with Asymptotically Normal Distri-745 bution, The Annals of Mathematical Statistics, vol.19, pp.293-325, 1948. ,
Sparse Convex Optimization Methods for Machine Learning, 2011. ,
Revisiting Frank-Wolfe: Projection-Free Sparse Convex Optimization, 2013. ,
Learning Low-Dimensional Metrics, 2017. ,
Regularized Distance Metric Learning: Theory and Algorithm, 2009. ,
, , p.755, 2012.
, Metric Learning, NIPS, pp.2582-2590
Metric Learning: A Survey, Foundations and Trends in Machine Learning, vol.5, pp.287-364, 2012. ,
On the Global Linear Convergence of FrankWolfe Optimization Variants, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01248675
An Introduction to Chemoinformatics, 2007. ,
U-Statistics: Theory and Practice, 1990. ,
, Robust Structural Metric Learning, 2013.
, Similarity Learning for High-Dimensional, vol.765, 2015.
, , pp.653-662
Low-Rank Similarity Metric Learning in High Dimensions, 2015. ,
On the method of bounded differences, Surveys in combinatorics, vol.141, pp.148-188, 1989. ,
An Efficient Sparse Metric Learning in High-Dimensional Space via l1-Penalized Log-Determinant Regularization, 2009. ,
Towards Making High Dimensional Distance Metric Learning Practical, 2015. ,
An Integrated Framework for High Dimensional Distance Metric Learning and Its Application to Fine-Grained Visual Categorization, 2014. ,
Learning Sparse Metrics via Linear Programming, pp.367-373, 2006. ,
Learning a Distance Metric from Relative Comparisons, 2003. ,
Probability inequalities for the sum in sampling without replacement, The Annals of Statistics, vol.2, pp.39-48, 1974. ,
Understanding Machine Learning: 785 From Theory to Algorithms, 2014. ,
Positive Semidefinite Metric Learning Using Boosting-like Algorithms, Journal of Machine Learning Research, vol.13, pp.1007-1036, 2012. ,
, Sparse Compositional Metric Learning, pp.2078-2084, 2014.
URL : https://hal.archives-ouvertes.fr/hal-01430847
, Sparse Compositional Local Metric Learning, 2017.
Sample complexity of learning mahalanobis distance metrics, 2015. ,
Parametric Local Metric Learning for Nearest Neighbor Classification, NIPS, pp.1610-1618, 2012. ,
Distance Metric Learning for Large Margin Nearest Neighbor Classification, Journal of Machine Learning Research, vol.10, pp.207-244, 2009. ,
High-dimensional Similarity Learning via Dual-sparse Random Projection, 2018. ,
DOI : 10.24963/ijcai.2018/417
URL : https://www.ijcai.org/proceedings/2018/0417.pdf
Sparse Metric Learning via Smooth Optimization, NIPS, pp.2214-2222, 2009. ,
Distance Metric Learning with Eigenvalue Optimization, 805 Journal of Machine Learning Research, vol.13, pp.1-26, 2012. ,
Efficient Stochastic Optimization for Low-Rank Distance Metric Learning, 2017. ,
