Damping of structural vibrations with piezoelectric materials and passive electrical networks, J. Sound Vib, p.146, 1991. ,
Balanced calibration of resonant shunt circuits for piezoelectric vibration control, J. Intel. Mat. Syst. Str, vol.23, 2012. ,
Performance of piezoelectric shunts for vibration reduction, Smart. Mater. Struct, vol.21, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01082925
Piezoelectric vibration damping using resonant shunt circuits: an exact solution, 2014. ,
Design of inductors with high inductance values for resonant piezoelectric damping, Sensor. Actuat. A-Phys, vol.259, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01657528
Method for multiple mode piezoelectric shunting with single PZT transducer for vibration control, J. Intel. Mat. Syst. Str, vol.9, 1998. ,
Circuit analog of a beam and its application to multimodal vibration damping, using piezoelectric transducers, Int. J. Circ. Theor. App, vol.32, 2004. ,
URL : https://hal.archives-ouvertes.fr/hal-00499413
Multimodal vibration damping, Smart Mater. Struct, p.24, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01691077
Multimodal vibration damping of a plate by piezoelectric coupling to its analogous electrical network, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01691082
Analysis and application of a nonlinear vibration absorber, J. Vib. Control, vol.6, 2000. ,
Dynamics of autoparametric vibration absorbers using multiple pendulums, J. Sound Vib, p.246, 2001. ,
Energy pumping in nonlinear mechanical oscillators, Part II: resonance capture, J. Appl. Mech, p.68, 2001. ,
Nonlinear targeted energy transfer in mechanical and structural systems, Series: Solid Mechanics and Its Applications, 2009. ,
Nonlinear energy pumping under transient forcing with strongly nonlinear coupling: theoretical and experimental results, J. Sound Vib, vol.300, 2007. ,
URL : https://hal.archives-ouvertes.fr/hal-00815136
Experimental study of targeted energy transfer from an acoustic system to a nonlinear membrane absorber, J. Sound Vib, p.329, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-00461706
Chatter control in turning process with a nonlinear energy sink, Adv. Mat. Res, vol.698, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-01808190
On the response of the non-linear vibration absorber, Int. J. of Nonlin. Mech, p.24, 1989. ,
A fundamental study on impact dampers, Int J. Mach. Tool. Manu, vol.36, 1996. ,
A combined tuned absorber and pendulum impact damper under random excitation, J. Sound Vib, vol.216, 1998. ,
Application of non-linear multiple tuned mass dampers to suppress man-induced vibrations of a pedestrian Bridge, Earthq. Eng. Struct. D, vol.32, 2003. ,
Exploring the performance of a nonlinear tuned mass damper, J. Sound Vib, p.319, 2009. ,
Flutter control of a lifting surface via visco-hysteretic vibration absorbers, Int. J. Aeronaut. Space, vol.12, 2011. ,
Structural vibration reduction by switch shunting of piezoelectric elements: modeling and optimization, J. Intel. Mat. Syst. Str, vol.21, 2010. ,
A principle of similarity for nonlinear vibration absorbers, Physica D, vol.332, 2016. ,
The nonlinear piezoelectric tuned vibration absorber, Smart. Mater. Struct, vol.24, 2015. ,
Passive linearization of nonlinear resonances, J. Appl. Phys, vol.120, 2016. ,
The use of non-linear capacitors, Int. J. Electron, vol.58, 1985. ,
Magnetic measurements at low flux densities using the alternating current bridge, Bell Labs Tech. J, vol.15, 1936. ,
Characterization and modeling of magnetic domain wall dynamics using reconstituted hysteresis loops from Barkhausen noise, J Magn. Magn. Mater, p.432, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01570929
Presentation of the ECL benchmark, Mech. Syst. Signal Pr, vol.17, 2003. ,
Experimental demonstration of a 3D-printed nonlinear tuned vibration absorber, Conference Proceedings of the Society for Experimental Mechanics Series, vol.1, 2016. ,
VTT benchmark: application of the restoring force surface method, Mech. Syst. Signal Pr, vol.17, 2003. ,
