Wavelength Defragmentation for Seamless Migration - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Lightwave Technology Année : 2019
Dynamic traffic in optical networks leads to spectrum fragmentation, which significantly reduces network performance, i.e., increases blocking rate and reduces spectrum usage. Telecom operators face the operational challenge of operating non-disruptive defragmentation, i.e., within the make-before-break paradigm when dealing with lightpath rerouting in wavelength division multiplexed (WDM) fixed-grid optical networks. In this paper, we propose a make-before-break (MBB) Routing and Wavelength Assignment (RWA) defragmentation process, which provides the best possible lightpath network provisioning, i.e., with minimum bandwidth requirement. We tested extensively the models and algorithms we propose on four network topologies with different GoS (Grade of Service) defragmentation triggering events. We observe that, for a given throughput, the spectrum usage of the best make-before-break lightpath rerouting is always less than 2.5% away from that of an optimal lightpath provisioning.
RWA_MBB_JLT_hal.pdf (1.52 Mo) Télécharger le fichier
hal-02167682 , version 1 (28-06-2019)
Brigitte Jaumard, Hamed Pouya, David Coudert. Wavelength Defragmentation for Seamless Migration. Journal of Lightwave Technology, 2019, 37 (17), pp.4382-4393. ⟨10.1109/JLT.2019.2924914⟩. ⟨hal-02167682⟩
129 Consultations
290 Téléchargements
