Clean up atomics, non-normative changes
Whereas its intent is clear, the text in the C standard that concerns atomics has several consistency problems. There are contradictions and the standard vocabulary is not always applied correctly.-This document is a follow up of the series of documents N1955, N2064, and N2329. It contains an update on the non-normative changes that WG14 has agreed to during the London 2019 meeting.
