Clean up atomics, non-normative changes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2019
Whereas its intent is clear, the text in the C standard that concerns atomics has several consistency problems. There are contradictions and the standard vocabulary is not always applied correctly.-This document is a follow up of the series of documents N1955, N2064, and N2329. It contains an update on the non-normative changes that WG14 has agreed to during the London 2019 meeting.
n2389+appendix.pdf (790.42 Ko) Télécharger le fichier
hal-02167823 , version 1 (28-06-2019)
  • HAL Id : hal-02167823 , version 1
Jens Gustedt. Clean up atomics, non-normative changes: proposal for integration to C2x. [Technical Report] N2389, ISO JTC1/SC22/WG14. 2019. ⟨hal-02167823⟩
46 Consultations
68 Téléchargements
