Remove ATOMIC VAR INIT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2022
Because of syntactical problems and because it had been found to be basically useless for the intended use case, the macro ATOMIC_VAR_INIT had been marked obsolete in C17. We propose to remove it completely.
Fichier non déposé
hal-02167838 , version 1 (28-06-2019)
hal-02167838 , version 2 (13-01-2022)
  • HAL Id : hal-02167838 , version 2
Jens Gustedt. Remove ATOMIC VAR INIT. [Research Report] N2886, ISO JTC1/SC22/WG14. 2022. ⟨hal-02167838v2⟩
68 Consultations
48 Téléchargements
