Revise spelling of keywords and make them feature tests
Jens Gustedt 1
1 CAMUS - Compilation pour les Architectures MUlti-coeurS
Inria Nancy - Grand Est, ICube - Laboratoire des sciences de l'ingénieur, de l'informatique et de l'imagerie
Abstract : Over time C has integrated some new features as keywords (some genuine, some from C++) but the naming strategy has not be entirely consistent: some were integrated using non-reserved names (const, inline) others were integrated in an underscore-capitalized form. For some of them, the use of the lowercase form then is ensured via a set of library header files. The reason for this complicated mechanism had been backwards compatibility for existing code bases. Since now years or even decades have gone by, we think that it is time to switch and to use to the primary spelling. This is a follow-up paper to N2368 where we reduce the focus to the list of keywords that found consensus in the WG14 London 2019 meeting. Other papers will build on this for those keywords or features that need more investigation.
Document type :
Reports
Complete list of metadatas
https://hal.inria.fr/hal-02167870
Contributor : Jens Gustedt <>
Submitted on : Friday, June 28, 2019 - 11:33:09 AM
Last modification on : Saturday, June 29, 2019 - 1:35:42 AM
File
n2392+appendix.pdf
Identifiers
  • HAL Id : hal-02167870, version 1
Citation
Jens Gustedt. Revise spelling of keywords and make them feature tests. [Research Report] N2392, ISO JTC1/SC22/WG14. 2019. ⟨hal-02167870⟩
Share
Metrics
Record views
22
Files downloads
127
