Mean-field limit of interacting 2D nonlinear stochastic spiking neurons - Archive ouverte HAL Access content directly
Preprints, Working Papers, ... Year :
(1) , (1) , (1)
1
In this work, we propose a nonlinear stochastic model of a network of stochastic spiking neurons. We heuristically derive the mean-field limit of this system. We then design a Monte Carlo method for the simulation of the microscopic system, and a finite volume method (based on an upwind implicit scheme) for the mean-field model. The finite volume method respects numerical versions of the two main properties of the mean-field model, conservation and positivity, leading to existence and uniqueness of a numerical solution. As the size of the network tends to infinity, we numerically observe propagation of chaos and convergence from an individual description to a mean-field description. Numerical evidences for the existence of a Hopf bifurcation (synonym of synchronised activity) for a sufficiently high value of connectivity, are provided.
Dates and versions
hal-02170948 , version 1 (02-07-2019)
Identifiers
Cite
Benjamin Aymard, Fabien Campillo, Romain Veltz. Mean-field limit of interacting 2D nonlinear stochastic spiking neurons. 2019. ⟨hal-02170948⟩
81 View
0 Download
Share
