Algorithmic aspects of elliptic bases in finite field discrete logarithm algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Mathematics of Communications Année : 2022
Elliptic bases, introduced by Couveignes and Lercier in 2009, give an elegant way of representing finite field extensions. A natural question which seems to have been considered independently by several groups is to use this representation as a starting point for small characteristic finite field discrete logarithm algorithms. This idea has been recently proposed by two groups working on it, in order to achieve provable quasi-polynomial time for discrete logarithms in small characteristic finite fields. In this paper, we don't try to achieve a provable algorithm but, instead, investigate the practicality of heuristic algorithms based on elliptic bases. Our key idea, is to use a different model of the elliptic curve used for the elliptic basis that allows for a relatively simple adaptation of the techniques used with former Frobenius representation algorithms. We haven't performed any record computation with this new method but our experiments with the field F 3 1345 indicate that switching to elliptic representations might be possible with performances comparable to the current best practical methods.
AlgoECdlog_journal.pdf (612.44 Ko) Télécharger le fichier
hal-02173688 , version 1 (04-07-2019)
hal-02173688 , version 2 (24-10-2022)
Paternité
Antoine Joux, Cécile Pierrot. Algorithmic aspects of elliptic bases in finite field discrete logarithm algorithms. Advances in Mathematics of Communications, In press, ⟨10.3934/amc.2022085⟩. ⟨hal-02173688v2⟩
245 Consultations
159 Téléchargements
