New interface
Journal articles
Global Synchronization Analysis of Droop-Controlled Microgrids: A Multivariable Cell Structure Approach
Abstract : The microgrid concept represents a promising approach to facilitate the large-scale integration of renewable energy sources. Motivated by this, the problem of global synchronization in droop-controlled microgrids with radial topology is considered. To this end, at rst a necessary and sucient condition for existence of equilibria is established in terms of the droop gains and the network parameters. Then, the local stability properties of the equilibria are characterized. Subsequently, sucient conditions for almost global synchronization are derived by means of the multivariable cell structure approach recently proposed in [1]. The latter is an extension of the powerful cell structure principle developed by Leonov and Noldus to nonlinear systems that are periodic with respect to several state variables and possess multiple invariant solutions. The analysis is illustrated via numerical examples.
Document type :
Journal articles
Complete list of metadata
Cited literature [62 references]  Display  Hide  Download
https://hal.inria.fr/hal-02177492
Contributor : Denis Efimov Connect in order to contact the contributor
Submitted on : Thursday, July 11, 2019 - 11:22:00 AM
Last modification on : Tuesday, November 22, 2022 - 2:26:16 PM
File
_globalSyncRadialMGs_final.pdf
Identifiers
Citation
Johannes Schiffer, Denis Efimov, Romeo Ortega. Global Synchronization Analysis of Droop-Controlled Microgrids: A Multivariable Cell Structure Approach. Automatica, 2019, 109, pp.108550. ⟨10.1016/j.automatica.2019.108550⟩. ⟨hal-02177492v2⟩
Share
Metrics
Record views
187
Files downloads
484
