Conference papers
An In-Process BSR-Noise Detection System for Car Door Trims
Abstract : The Buzz, Squeak, and Rattle (BSR) noises coming from car body parts are often caused by defective assembly. This paper presents an in-process BSR noise detection system for car door trims. A car door trim is slowly pressed down by a pneumatic pusher, and then the acoustic signals measured right above the door trim and on the four corners of the noise detection workstation are monitored for noise source localization by the time difference of arrival method and the relative signal strengths. Finally, the energy of BSR noise is examined by the discretized frequency information of the localized signals.
Document type :
Conference papers
Complete list of metadata
Cited literature [5 references]  Display  Hide  Download
https://hal.inria.fr/hal-02177851
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, July 9, 2019 - 1:43:59 PM
Last modification on : Tuesday, July 9, 2019 - 1:51:30 PM
File
472851_1_En_5_Chapter.pdf
Identifiers
Citation
Woonsang Baek, Duck Young Kim. An In-Process BSR-Noise Detection System for Car Door Trims. IFIP International Conference on Advances in Production Management Systems (APMS), Aug 2018, Seoul, South Korea. pp.35-38, ⟨10.1007/978-3-319-99707-0_5⟩. ⟨hal-02177851⟩
Share
Metrics
Record views
59
Files downloads
61
