The Impacts of Quick Response in a Dual-Channel Supply Chain - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
We consider the quick response (QR) in a dual-channel supply chain in which a manufacturer sells products through both its own direct channel and a retailer. With QR, the retailer has an opportunity to reorder after the random demand is realized and the manufacturer is able to reproduce after that. We characterize the equilibrium decisions for each channel and investigate the impacts of QR on the decisions and profits. Through numerical analysis, we show that QR may be beneficial to the manufacturer whereas either increases or decreases the optimal expected profit of the retailer. In addition, the supply chain is able to achieve Pareto improvement with QR under certain conditions.
472851_1_En_12_Chapter.pdf (361.56 Ko) Télécharger le fichier
hal-02177869 , version 1 (09-07-2019)
Paternité
Huihui Zhang, Danqin Yang. The Impacts of Quick Response in a Dual-Channel Supply Chain. IFIP International Conference on Advances in Production Management Systems (APMS), Aug 2018, Seoul, South Korea. pp.89-96, ⟨10.1007/978-3-319-99707-0_12⟩. ⟨hal-02177869⟩
32 Consultations
59 Téléchargements
