Energy-aware scheduling for improving manufacturing process sustainability: a mathematical model for flexible flow shops, CIRP Annals-Manufacturing Technology, vol.61, issue.1, pp.459-462, 2012. ,
Energy-efficient scheduling for a flexible flow shop using an improved genetic-simulated annealing algorithm, Robotics and Computer-Integrated Manufacturing, vol.29, issue.5, pp.418-429, 2013. ,
A multi-agent framework to solve energy-aware unrelated parallel machine scheduling problems with machine-dependent energy consumption and sequence-dependent setup time, ICAPS, 2018. ,
Assessment of a multi agent system for energy aware off-line scheduling from a real case manufacturing data set, COPLAS, p.35, 2016. ,
A multi-agent approach using dynamic constraints to solve energy-aware unrelated parallel machine scheduling problem with energy-dependent and sequence-dependent setup time, pp.31-37, 2017. ,
Facing energy-aware scheduling: a multiobjective extension of a scheduling support system for improving energy efficiency in a moulding industry, Soft Computing, pp.1-12, 2015. ,
Energy-aware decision support for production scheduling. Decision Support Systems 93, pp.88-97, 2017. ,
Assessment of mathematical programming and agentbased modelling for off-line scheduling: Application to energy aware manufacturing, CIRP Annals -Manufacturing Technology, vol.65, pp.405-408, 2016. ,
Industrial sustainability: challenges, perspectives, actions, International Journal of Business Innovation and Research, vol.7, issue.2, pp.143-163, 2013. ,
Rescheduling manufacturing systems: a framework of strategies, policies, and methods, Journal of scheduling, vol.6, issue.1, pp.39-62, 2003. ,
Bi-objective optimization of a single machine batch scheduling problem with energy cost consideration, Journal of cleaner production, vol.137, pp.1205-1215, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01388548
