Methods for fault detection, diagnostics, and prognostics for building systemsa review, part i, Hvac&R Research, vol.11, issue.1, pp.3-25, 2005. ,
Fault diagnosis of an air-handling unit using artificial neural networks, Transactions-American Society of Heating Refrigerating and Air Conditioning Engineers, vol.102, pp.540-549, 1996. ,
Fault diagnosis for sensors in air handling unit based on neural network pre-processed by wavelet and fractal, Energy and buildings, vol.44, pp.7-16, 2012. ,
Wavelet neural network-based fault diagnosis in airhandling units, HVAC&R Research, vol.14, issue.6, pp.959-973, 2008. ,
Detection and diagnosis of ahu sensor faults using principal component analysis method, Energy Conversion and Management, vol.45, issue.17, pp.2667-2686, 2004. ,
Fault detection and diagnosis based on improved pca with jaa method in vav systems, Building and Environment, vol.42, issue.9, pp.3221-3232, 2007. ,
Fault detection, diagnosis and data recovery for a real building heating/cooling billing system, Energy Conversion and Management, vol.51, issue.5, pp.1015-1024, 2010. ,
An isolation enhanced pca method with expertbased multivariate decoupling for sensor fdd in air-conditioning systems, Applied Thermal Engineering, vol.29, issue.4, pp.712-722, 2009. ,
Arx model based fault detection and diagnosis for chillers using support vector machines, Energy and Buildings, vol.81, pp.287-295, 2014. ,
Model-based fault detection and diagnosis of hvac systems using support vector machine method, International Journal of refrigeration, vol.30, issue.6, pp.1104-1114, 2007. ,
The regression analysis of binary sequences, Journal of the Royal Statistical Society. Series B (Methodological), pp.215-242, 1958. ,
Degradation assessment and fault modes classification using logistic regression, Journal of manufacturing Science and Engineering, vol.127, issue.4, pp.912-914, 2005. ,
Real heat recovery with air handling units, Energy and Buildings, vol.33, issue.5, pp.495-502, 2001. ,
Sustainable plm through intelligent products, Engineering Applications of Artificial Intelligence, vol.26, issue.2, pp.789-799, 2013. ,
