A Novel Timetabling Algorithm for a Furnace Process for Semiconductor Fabrication with Constrained Waiting and Frequency-based Setups, OR Spectrum, vol.29, issue.3, pp.391-419, 2007. ,
Strategic capacity planning for smart production: Decision modeling under demand uncertainty, Applied Soft Computing, vol.68, pp.900-909, 2018. ,
, Spare parts classification and demand forecasting for stock control: Investigating the gap between research and practice, vol.40, pp.722-737, 2012.
A survey of semiconductor supply chain models part III: master planning, production planning, and demand fulfilment, International Journal of Production Research, pp.1-20, 2017. ,
Improving The Performance of Inventory Control-Taking W Company as an Example, The 17th International Conference on Electronic Business, pp.289-292, 2017. ,
Forecasting for the ordering and stock-holding of spare parts, J Oper Res Soc, vol.55, issue.4, pp.431-437, 2004. ,
On the categorization of demand patterns, J. Oper. Res. Soc, vol.56, issue.5, pp.495-503, 2004. ,
A multicriteria framework for inventory classification and control with application to intermittent demand, Journal of MultiCriteria Decision Analysis, vol.24, issue.5-6, pp.275-285, 2017. ,
Forecasting and Stock Control for Intermittent Demands, Oper. Res. Q, vol.23, issue.3, pp.289-303, 1972. ,
The accuracy of intermittent demand estimates, International Journal of forecasting, vol.21, issue.2, pp.303-314, 2005. ,
Intermittent demand: Linking forecasting to inventory obsolescence, European Journal of Operational Research, vol.214, issue.3, pp.606-615, 2011. ,
Lumpy demand forecasting using neural networks, International Journal of Production Economics, vol.111, issue.2, pp.409-420, 2008. ,
Intermittent demand forecasts with neural networks, International Journal of Production Economics, vol.143, issue.1, pp.198-206, 2013. ,
Single-hidden layer neural networks for forecasting intermittent demand, International Journal of Production Economics, vol.183, pp.116-128, 2017. ,
RFM and CLV: Using iso-value curves for customer base analysis, Journal of Marketing Research, vol.42, issue.4, pp.415-430, 2005. ,
Another look at forecast-accuracy metrics for intermittent demand, Foresight: The International Journal of Applied Forecasting, vol.4, issue.4, pp.43-46, 2006. ,
