Distributed energy-efficient power optimization for relay-aided heterogeneous networks, 2014 12th International Symposium on Modeling and Optimization in Mobile, Ad Hoc, and Wireless Networks (WiOpt), 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01098833
External Libraries, Introducing Vala Programming, pp.211-234, 2019. ,
Conflict analysis in mixed integer programming, Discrete Optimization, vol.4, issue.1, pp.4-20, 2007. ,
Optimal solutions for routing problems with profits, Discrete Applied Mathematics, vol.161, issue.4-5, pp.547-557, 2013. ,
The capacitated team orienteering and profitable tour problems, Journal of the Operational Research Society, vol.60, issue.6, pp.831-842, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-01299943
A computational study of exact knapsack separation for the generalized assignment problem, Computational Optimization and Applications, vol.45, issue.3, pp.543-555, 2008. ,
An Exact Algorithm for the Pickup and Delivery Problem with Time Windows, Operations Research, vol.59, issue.2, pp.414-426, 2011. ,
An exact algorithm for the vehicle routing problem based on the set partitioning formulation with additional cuts, Mathematical Programming, vol.115, issue.2, pp.351-385, 2007. ,
A unified exact method for solving different classes of vehicle routing problems, Mathematical Programming, vol.120, issue.2, pp.347-380, 2008. ,
New Route Relaxation and Pricing Strategies for the Vehicle Routing Problem, Operations Research, vol.59, issue.5, pp.1269-1283, 2011. ,
On an Integer Program for a Delivery Problem, Operations Research, vol.12, issue.2, pp.300-304, 1964. ,
Improved lower bounds and exact algorithm for the capacitated arc routing problem, Mathematical Programming, vol.137, issue.1-2, pp.409-452, 2011. ,
OR-Library: Distributing Test Problems by Electronic Mail, Journal of the Operational Research Society, vol.41, issue.11, pp.1069-1072, 1990. ,
The capacitated arc routing problem: Valid inequalities and facets, Computational Optimization and Applications, vol.10, issue.2, pp.165-187, 1998. ,
A branch-and-cut-and-price algorithm for one-dimensional stock cutting and two-dimensional two-stage cutting, European Journal of Operational Research, vol.171, issue.1, pp.85-106, 2006. ,
A branch-price-and-cut algorithm for the min-maxk-vehicle windy rural postman problem, Networks, vol.63, issue.1, pp.34-45, 2013. ,
A branch?and?cut algorithm for the Team Orienteering Problem, International Transactions in Operational Research, vol.25, issue.2, pp.627-635, 2017. ,
Cut-First Branch-and-Price-Second for the Capacitated Arc-Routing Problem, Operations Research, vol.60, issue.5, pp.1167-1182, 2012. ,
Bin packing and related problems: General arc-flow formulation with graph compression, Computers & Operations Research, vol.69, pp.56-67, 2016. ,
The vehicle routing problem with service level constraints, European Journal of Operational Research, vol.265, issue.2, pp.544-558, 2018. ,
On the complete set packing and set partitioning polytopes: Properties and rank 1 facets, Operations Research Letters, vol.46, issue.4, pp.389-392, 2018. ,
A branch-and-price algorithm for the Minimum Latency Problem, Computers & Operations Research, vol.93, pp.66-78, 2018. ,
Lower bounds and algorithms for the 2-dimensional vector packing problem, Discrete Applied Mathematics, vol.111, issue.3, pp.231-262, 2001. ,
The team orienteering problem, European Journal of Operational Research, vol.88, issue.3, pp.464-474, 1996. ,
An Algorithm for the Vehicle-dispatching Problem, Journal of the Operational Research Society, vol.20, issue.3, pp.309-318, 1969. ,
Exact algorithms for the vehicle routing problem, based on spanning tree and shortest path relaxations, Mathematical Programming, vol.20, issue.1, pp.255-282, 1981. ,
Iterative aggregation and disaggregation algorithm for pseudo-polynomial network flow models with side constraints, European Journal of Operational Research, vol.258, issue.2, pp.467-477, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01410170
A new exact algorithm for the multi-depot vehicle routing problem under capacity and route length constraints, Discrete Optimization, vol.12, pp.129-146, 2014. ,
A tabu search heuristic for periodic and multi-depot vehicle routing problems, Networks, vol.30, issue.2, pp.105-119, 1997. ,
The Truck Dispatching Problem, Management Science, vol.6, issue.1, pp.80-91, 1959. ,
Enhanced Pseudo-polynomial Formulations for Bin Packing and Cutting Stock Problems, INFORMS Journal on Computing, vol.32, issue.1, pp.101-119, 2020. ,
Bin packing and cutting stock problems: Mathematical models and exact algorithms, European Journal of Operational Research, vol.255, issue.1, pp.1-20, 2016. ,
A Unified Framework for Deterministic Time Constrained Vehicle Routing and Crew Scheduling Problems, Fleet Management and Logistics, pp.57-93, 1998. ,
Strafprozessrecht, 1998. ,
Tabu Search, Partial Elementarity, and Generalizedk-Path Inequalities for the Vehicle Routing Problem with Time Windows, Transportation Science, vol.42, issue.3, pp.387-404, 2008. ,
JuMP: A Modeling Language for Mathematical Optimization, SIAM Review, vol.59, issue.2, pp.295-320, 2017. ,
Efficient Routeing for Winter Gritting, Journal of the Operational Research Society, vol.43, issue.11, pp.1031-1034, 1992. ,
Solving the team orienteering problem with cutting planes, Computers & Operations Research, vol.74, pp.21-30, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01300334
A hybrid grouping genetic algorithm for bin packing, Journal of Heuristics, vol.2, issue.1, pp.5-30, 1996. ,
Robust Branch-and-Cut-and-Price for the Capacitated Vehicle Routing Problem, Mathematical Programming, vol.106, issue.3, pp.491-511, 2005. ,
Parallelization of a two-phase metaheuristic for routing problems with time windows, Journal of Heuristics, vol.8, issue.3, pp.251-276, 2002. ,
A new branching strategy for time constrained routing problems with application to backhauling, Annals of Operations Research, vol.61, issue.1, pp.91-109, 1995. ,
Extended formulations and branch-and-cut algorithms for the Black-and-White Traveling Salesman Problem, European Journal of Operational Research, vol.262, issue.3, pp.908-928, 2017. ,
Bidirectional labeling in column-generation algorithms for pickup-and-delivery problems, European Journal of Operational Research, vol.266, issue.2, pp.521-530, 2018. ,
Gurobi announces Gurobi Optimizer 3.0, 2019. ,
Maximum-weight stable sets and safe lower bounds for graph coloring, Mathematical Programming Computation, vol.4, issue.4, pp.363-381, 2012. ,
Stabilized branch-and-price algorithms for vector packing problems, European Journal of Operational Research, vol.271, issue.2, pp.401-419, 2018. ,
Resource extension functions: properties, inversion, and generalization to segments, OR Spectrum, vol.30, issue.1, pp.113-148, 2007. ,
Path-Reduced Costs for Eliminating Arcs in Routing and Scheduling, INFORMS Journal on Computing, vol.22, issue.2, pp.297-313, 2010. ,
Subset-Row Inequalities Applied to the Vehicle-Routing Problem with Time Windows, Operations Research, vol.56, issue.2, pp.497-511, 2008. ,
Lagrangian duality applied to the vehicle routing problem with time windows, Computers & Operations Research, vol.33, issue.5, pp.1464-1487, 2006. ,
Handbook of Satisfiability, chapter Fundaments of branching heuristics, pp.205-244, 2009. ,
A branch and bound algorithm for the capacitated vehicle routing problem, Operations-Research-Spektrum, vol.5, issue.2, pp.77-85, 1983. ,
An abstract model for branching and its application to mixed integer programming, Mathematical Programming, vol.166, issue.1, pp.369-405, 2017. ,
A Metaheuristic for the Pickup and Delivery Problem with Time Windows, International Journal on Artificial Intelligence Tools, vol.12, issue.02, pp.173-186, 2003. ,
Solving capacitated arc routing problems using a transformation to the CVRP, Computers & Operations Research, vol.33, issue.6, pp.1823-1837, 2006. ,
CVRPSEP: A package of separation routines for the capacitated vehicle routing problem. Aarhus School of Business, 2003. ,
A new branch-and-cut algorithm for the capacitated vehicle routing problem, Mathematical Programming, vol.100, issue.2, pp.423-445, 2004. ,
An improved branch-cut-and-price algorithm for the two-echelon capacitated vehicle routing problem, Computers & Operations Research, vol.114, p.104833, 2020. ,
URL : https://hal.archives-ouvertes.fr/hal-02112287
Solving the generalized assignment problem: An optimizing and heuristic approach, INFORMS Journal on Computing, vol.15, issue.3, pp.249-266, 2003. ,
Algorithms for non-linear and stochastic resource constrained shortest path, Mathematical Methods of Operations Research, vol.89, issue.2, pp.281-317, 2018. ,
Improved Branch-Cut-and-Price for Capacitated Vehicle Routing, Integer Programming and Combinatorial Optimization, vol.8494, pp.393-403, 2014. ,
New enhancements for the exact solution of the vehicle routing problem with time windows, INFORMS Journal on Computing, vol.29, issue.3, pp.489-502, 2017. ,
Improved branch-cut-andprice for capacitated vehicle routing, Mathematical Programming Computation, vol.9, issue.1, pp.61-100, 2017. ,
Limited memory rank-1 cuts for vehicle routing problems, Operations Research Letters, vol.45, issue.3, pp.206-209, 2017. ,
Comparative analysis of capacitated arc routing formulations for designing a new branch-cut-and-price algorithm, Transportation Science, vol.53, issue.6, pp.1501-1799, 2019. ,
Ruslan Sadykov, and François Vanderbeck. Branch-and-cutand-price for the robust capacitated vehicle routing problem with knapsack uncertainty, Operations Research, p.2020 ,
Enhanced branch-cut-and-price algorithm for heterogeneous fleet vehicle routing problems, European Journal of Operational Research, vol.270, pp.530-543, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01664844
Automation and Combination of Linear-Programming Based Stabilization Techniques in Column Generation, INFORMS Journal on Computing, vol.30, issue.2, pp.339-360, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01077984
A generic exact solver for vehicle routing and related problems, Integer Programming and Combinatorial Optimization, vol.11480, pp.354-369, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02178171
Chvátal-Gomory Rank-1 Cuts Used in a Dantzig-Wolfe Decomposition of the Vehicle Routing Problem with Time Windows, Operations Research/Computer Science Interfaces, pp.397-419 ,
Integer program reformulation for robust branch-andcut-and-price, Annals of Mathematical Programming in Rio, pp.56-61, 2003. ,
An exact method with variable fixing for solving the generalized assignment problem, Computational Optimization and Applications, vol.52, pp.629-644, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01320026
Symmetry helps: Bounded bi-directional dynamic programming for the elementary shortest path problem with resource constraints, Discrete Optimization, vol.3, issue.3, pp.255-273, 2006. ,
Dynamic ng-path relaxation for the delivery man problem, Transportation Science, vol.48, issue.3, pp.413-424, 2014. ,
Branching decisions in branch-and-cut-and-price algorithms for vehicle routing problems. Presentation in Column Generation, 2012. ,
Branch and Cut and Price for the Pickup and Delivery Problem with Time Windows, Transportation Science, vol.43, issue.3, pp.267-286, 2009. ,
An integer programming approach to scheduling, Computer Scheduling of Public Transport: Urban Passenger Vehicle and Crew Scheduling, pp.269-280, 1981. ,
A Bucket Graph?Based Labeling Algorithm with Application to Vehicle Routing, Transportation Science, p.2020, 2020. ,
Primal Heuristics for Branch and Price: The Assets of Diving Methods, INFORMS Journal on Computing, vol.31, issue.2, pp.251-267, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01237204
us army army missile command sinosoviet bloc missile and space technology june 1965 top secret dinar ruff ,
Algorithms for the Vehicle Routing and Scheduling Problems with Time Window Constraints, Operations Research, vol.35, issue.2, pp.254-265, 1987. ,
New benchmark instances for the Capacitated Vehicle Routing Problem, European Journal of Operational Research, vol.257, issue.3, pp.845-858, 2017. ,
BaPCod -a generic Branch-And-Price Code, 2018. ,
Reformulation and Decomposition of Integer Programs, 50 Years of Integer Programming 1958-2008, pp.431-502, 2009. ,
URL : https://hal.archives-ouvertes.fr/inria-00392254
A New Branch-and-Price-and-Cut Algorithm for One-Dimensional Bin-Packing Problems, INFORMS Journal on Computing, vol.32, issue.2, pp.428-443, 2020. ,
