Processable Low-Bandgap Polymers for Photovoltaic Applications?, Chemistry of Materials, vol.23, issue.3, pp.456-469, 2011. ,
Low bandgap semiconducting polymers for polymeric photovoltaics, Chemical Society Reviews, vol.45, issue.17, pp.4825-4846, 2016. ,
Low-Bandgap Near-IR Conjugated Polymers/Molecules for Organic Electronics, Chemical Reviews, vol.115, issue.23, pp.12633-12665, 2015. ,
Functionalized regioregular polythiophenes: towards the development of biochromic sensors, Chem. Commun., issue.24, pp.2761-2762, 1996. ,
Chromism of soluble polythienylenes, Journal of Polymer Science Part B: Polymer Physics, vol.25, issue.5, pp.1071-1078, 1987. ,
Ionochromic and Thermochromic Phenomena in a Regioregular Polythiophene Derivative Bearing Oligo(oxyethylene) Side Chains, Chemistry of Materials, vol.8, issue.12, pp.2843-2849, 1996. ,
Self-assembly and phase transformations of ?-conjugated block copolymers that bend and twist: from rigid-rod nanowires to highly curvaceous gyroids, Soft Matter, vol.7, issue.21, p.10429, 2011. ,
Self-Seeded Growth of Poly(3-hexylthiophene) (P3HT) Nanofibrils by a Cycle of Cooling and Heating in Solutions, Macromolecules, vol.45, issue.18, pp.7504-7513, 2012. ,
Direct visual indication of pH windows: 'off-on-off' fluorescent PET (photoinduced electron transfer) sensors/switches, Chemical Communications, issue.21, pp.2399-2400, 1996. ,
Protonation and Subsequent Intramolecular Hydrogen Bonding as a Method to Control Chain Structure and Tune Luminescence in Heteroatomic Conjugated Polymers, Journal of the American Chemical Society, vol.124, issue.21, pp.6049-6055, 2002. ,
Lewis Acid?Base Chemistry of 7-Azaisoindigo-Based Organic Semiconductors, ACS Applied Materials & Interfaces, vol.9, issue.29, pp.24788-24796, 2017. ,
Modification of pyridine-based conjugated polymer films via Lewis acid: halochromism, characterization and macroscopic gradation patterning, Polymer Chemistry, vol.2, issue.12, p.2764, 2011. ,
Family of Diazapentalene Chromophores and Narrow-Band-Gap Polymers: Synthesis, Halochromism, Halofluorism, and Visible?Near Infrared Photodetectivity, Chemistry of Materials, vol.24, issue.12, pp.2364-2372, 2012. ,
Near-Infrared Thermochromic Diazapentalene Dyes, Advanced Materials, vol.24, issue.12, pp.1582-1588, 2012. ,
Band Gap Control in Conjugated Oligomers via Lewis Acids, Journal of the American Chemical Society, vol.131, issue.31, pp.10802-10803, 2009. ,
Color Tuning in Polymer Light-Emitting Diodes with Lewis Acids, Angewandte Chemie International Edition, vol.51, issue.30, pp.7495-7498, 2012. ,
Heteroatomic Conjugated Polymers and the Spectral Tuning of Electroluminescence via a Supramolecular Coordination Strategy, Macromolecular Rapid Communications, vol.37, issue.22, pp.1807-1813, 2016. ,
Rational Design of Ratiometric Near-Infrared Fluorescent pH Probes with Various pKaValues, Based on Aminocyanine, Journal of the American Chemical Society, vol.133, issue.10, pp.3401-3409, 2011. ,
Organic Ternary Solar Cells: A Review, Advanced Materials, vol.25, issue.31, pp.4245-4266, 2013. ,
Small-Bandgap Semiconducting Polymers with High Near-Infrared Photoresponse, Journal of the American Chemical Society, vol.136, issue.34, pp.12130-12136, 2014. ,
Two-Photon-Excited Silica and Organosilica Nanoparticles for Spatiotemporal Cancer Treatment, Advanced Healthcare Materials, vol.7, issue.7, p.1701248, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01781459
Advances in Organic Near-Infrared Materials and Emerging Applications, The Chemical Record, vol.16, issue.3, pp.1531-1548, 2016. ,
Progress on Photothermal Conversion in the Second NIR Window Based on Conjugated Polymers, Asian Journal of Organic Chemistry, vol.7, issue.11, pp.2201-2212, 2018. ,
Stability of organic solar cells: challenges and strategies, Chemical Society Reviews, vol.45, issue.9, pp.2544-2582, 2016. ,
Chain-length dependence of electronic and electrochemical properties of conjugated systems: polyacetylene, polyphenylene, polythiophene, and polypyrrole, Journal of the American Chemical Society, vol.105, issue.22, pp.6555-6559, 1983. ,
Optical Bandgaps of ?-Conjugated Organic Materials at the Polymer Limit: Experiment and Theory, Advanced Materials, vol.19, issue.2, pp.173-191, 2007. ,
Computational engineering of low bandgap copolymers, Frontiers in Chemistry, vol.1, pp.35-47, 2013. ,
Calculation of low bandgap homopolymers: Comparison of TD-DFT methods with experimental oligomer series, Chemical Physics Letters, vol.645, pp.169-173, 2016. ,
Reviewing Extrapolation Procedures of the Electronic Properties on the ?-Conjugated Polymer Limit, The Journal of Physical Chemistry A, vol.116, issue.28, pp.7571-7583, 2012. ,
An Oligomer Study on Small Band Gap Polymers, The Journal of Physical Chemistry A, vol.112, issue.43, pp.10764-10773, 2008. ,
Optical properties of donor?acceptor conjugated copolymers: A computational study, Chemical Physics Letters, vol.678, pp.9-16, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01505581
The M06 suite of density functionals for main group thermochemistry, thermochemical kinetics, noncovalent interactions, excited states, and transition elements: two new functionals and systematic testing of four M06-class functionals and 12 other functionals, Theoretical Chemistry Accounts, vol.120, issue.1-3, pp.215-241, 2007. ,
Improved accuracy with medium cost computational methods for the evaluation of bond length alternation of increasingly long oligoacetylenes, Physical Chemistry Chemical Physics, vol.9, issue.44, p.5874, 2007. ,
Relevance of the DFT method to study expanded porphyrins with different topologies, Journal of Computational Chemistry, vol.38, issue.32, pp.2819-2828, 2017. ,
Simple and accurate correlation of experimental redox potentials and DFT-calculated HOMO/LUMO energies of polycyclic aromatic hydrocarbons, Journal of Molecular Modeling, vol.19, issue.7, pp.2845-2848, 2012. ,
Quantum Mechanical Continuum Solvation Models, Chemical Reviews, vol.105, issue.8, pp.2999-3094, 2005. ,
Über das Absorptionsspektrum der Polyene, Helvetica Chimica Acta, vol.31, issue.6, pp.1780-1799, 1948. ,
Gaussian 09 revision D01, 2009. ,
Dithioketopyrrolopyrrole (DTPP)-based conjugated polymers prepared upon thionation with Lawesson's reagent, Polymer Chemistry, vol.4, issue.13, p.3755, 2013. ,
Effect of acids on the infrared spectra of the Schiff base of trans-retinal, The Journal of Physical Chemistry, vol.91, issue.9, pp.2282-2287, 1987. ,
pKa values in organic chemistry ? Making maximum use of the available data, Tetrahedron Letters, vol.59, issue.42, pp.3738-3748, 2018. ,
Electronegativity and Lewis acid strength, Journal of the American Chemical Society, vol.112, issue.9, pp.3401-3403, 1990. ,
