The Principal Component Analysis and Cluster Analysis of Trace Elements in Gentian - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Xin Zhao
  • Fonction : Auteur
  • PersonId : 1050485
Yang Jiao
  • Fonction : Auteur
  • PersonId : 1020485
Haijiao Yu
  • Fonction : Auteur
  • PersonId : 1046237
Quanming Li
  • Fonction : Auteur
  • PersonId : 1050488
Guogang Zhao
  • Fonction : Auteur
  • PersonId : 1046238
In this paper, using principal component analysis and cluster analysis method, combining with the statistics software MATLAB. The Qingyuan rough gentian, Zuojia rough gentian, Zuojia leaf gentiana system clustering analysis of experimental data. Main ingredients swertia glycosides, Swertia bitter glycosides, gentian bitter glycosides and oleanolic acid and ursolic acid, etc. Cluster analysis results showed that the three principal component contribution rate of the Qingyuan rough gentian is 89.24%, the three principal component contribution rate of the Zuojia rough gentian is 89.85%, the three principal component contribution rate of the Zuojia leaf gentian is 93.56%. By cluster analysis to Qingyuan rough gentian, Zuojia rough gentian, Zuojia leaf gentiana aristata 3 groups of data were divided into 6, 5, 4 classes, and determine the appearance characteristics of the high quality gentian, provide the basis for breeding to select high quality gentian.
478221_1_En_29_Chapter.pdf (64.5 Ko) Télécharger le fichier
hal-02179966 , version 1 (11-07-2019)
Paternité
Xin Zhao, Mingwei Xu, Guoqing Sun, Yang Jiao, Haijiao Yu, et al.. The Principal Component Analysis and Cluster Analysis of Trace Elements in Gentian. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.291-297, ⟨10.1007/978-3-030-06155-5_29⟩. ⟨hal-02179966⟩
37 Consultations
23 Téléchargements
