The sensible heat fluxes over irrigated areas in western Turkey determined with a large aperture scintillometer, J]. Journal of Hydrology, vol.229, issue.1, pp.42-49, 2000. ,
Exploring eddy-covariance and largeaperture scintillameter measurements in an Amazonian rain forest, Agricultural and Forest Meteor, vol.148, issue.4, pp.680-690, 2008. ,
A verification of some methods to determine the fluxes of momentum sensible heat and water vapor using standard deviation and structure parameter of scalar meteorological quantities, J]. Boundary-Layer Meteorology, vol.63, pp.231-257, 1993. ,
Spatially averaged sensible heat fluxes measured over barley, Agricultural and Forest Meteorology, vol.107, pp.307-322, 2001. ,
The use of the scintillation technique for estimating and monitoring water consumption of olive orchards in a semiarid region ,
, Agriculture Water Management, vol.89, pp.173-184, 2007.
Methods of dealing with, the observational data of large aperture flashing research, Progress in Earth Sciences, vol.11, issue.25, pp.1187-1196, 2010. ,
Study of large aperture flicker meter observation method, Progress in Earth Sciences, pp.1140-1146, 2010. ,
Different underlying surface observational date processing analysis of large aperture flicker, Progress in Earth Sciences, vol.20, pp.172-176, 2009. ,
