The Nutrient Situations in the Major Alfalfa Producing Areas of China (in Chinese), J. Plant Nutri. Fert, vol.20, pp.503-509, 2014. ,
Pests and Their Control of Grassland Plants, China Agricultural Science and Technology Press, 2005. ,
, Compendium of Alfalfa Diseases and Pests, 2014.
The Methods of Diagnose, Investigation and Loss Evaluation for Forage Diseases (in Chinese), 2015. ,
Identification of Citrus Disease Using Color Texture Features and Discriminant Analysis, Comput. Electron. Agr, vol.52, pp.49-59, 2006. ,
A Review of Advanced Techniques for Detecting Plant Diseases, Comput. Electron. Agr, vol.72, pp.1-13, 2010. ,
Advances in Image Processing for Detection of Plant Diseases, J. Adv. Bioinfo. Res, vol.2, pp.135-141, 2011. ,
Image Recognition of Wheat Stripe Rust and Wheat Leaf Rust Based on Support Vector Machine (in Chinese), J. China Agric. Univ, vol.17, pp.72-79, 2012. ,
Image Recognition of Grape Downy Mildew and Grape Powdery Mildew Based on Support Vector Machine, CCTA 2011, Part III, vol.370, pp.151-162, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-01361130
Insect Pest Leaf Detection System Based on Information Fusion of Image and Spectrum (in Chinese), Trans. Chin. Soc. Agric. Mach, vol.44, pp.269-272, 2013. ,
Rice Diseases Classification Using Feature Selection and Rule Generation Techniques, Comput. Electron. Agr, vol.90, pp.76-85, 2013. ,
, Digital Image Processing Techniques for Detecting, Quantifying and Classifying Plant Diseases. Springerplus, vol.2, p.660, 2013.
An Automatic Method to Detect and Measure Leaf Disease Symptoms Using Digital Image Processing, Plant Dis, vol.98, pp.1709-1716, 2014. ,
Image-Based Field Monitoring of Cercospora Leaf Spot in Sugar Beet by Robust Template Matching and Pattern Recognition, Comput. Electron. Agr, vol.116, pp.65-79, 2015. ,
A Deep Learning Network for Recognizing Fruit Pathologic Images Based on Flexible Momentum (in Chinese), Trans. Chin. Soc. Agric. Mach, vol.46, pp.20-25, 2015. ,
Image-Based Phenotyping of Plant Disease Symptoms, Front. Plant Sci, vol.5, p.734, 2015. ,
A Review on the Main Challenges in Automatic Plant Disease Identification Based on Visible Range Images, Biosyst. Eng, vol.144, pp.52-60, 2016. ,
Recognition of Cucumber Downy Mildew Disease Based on Visual Saliency Map (in Chinese), Trans. Chin. Soc. Agric. Mach, vol.47, pp.270-274, 2016. ,
Ethiopian Coffee Plant Diseases Recognition Based on Imaging and Machine Learning Techniques, Int. J. Database Theor. Appl, vol.9, pp.79-88, 2016. ,
Design and Application of Rice Disease Image Recognition System Based on Android (in Chinese), Comput. Eng. Sci, vol.37, pp.1366-1371, 2015. ,
Development of a Single-Leaf Disease Severity Automatic Grading System Based on Image Processing, Lect. Notes Electr. Eng, vol.212, pp.665-675, 2013. ,
On Developing and Enhancing Plant-Level Disease Rating Systems in Real Fields, Pattern Recogn, vol.53, pp.287-299, 2016. ,
Ridge Estimators in Logistic Regression, J. Roy. Stat. Soc. Series C (Appl. Stat.), vol.41, pp.191-201, 1992. ,
Threshold Selection Method from Gray-Level Histograms, IEEE T. Syst. Man Cy, vol.9, pp.62-66, 1979. ,
Recognition of Four Different Alfalfa Leaf Diseases Based on Image Processing Technology (in Chinese), J. China Agric. Univ, vol.21, pp.65-75, 2016. ,
Evaluation: from Precision, Recall and F-Measure to ROC, Informedness, Markedness and Correlation, J. Mach. Learn. Tech, vol.2, pp.37-63, 2011. ,
Similarity of Color Images, Proc. SPIE Int. Soc. Opt. Eng, vol.2420, pp.381-392, 1995. ,
, Digital Image Processing Using MATLAB (in Chinese). Publishing House of Electronics Industry, 2005.
, Chinese). Publishing House of Electronics Industry, 2011.
URL : https://hal.archives-ouvertes.fr/hal-00972549
Correlation-Based Feature Selection for Machine Learning, 1999. ,
Identification of Alfalfa Leaf Diseases Using Image Recognition Technology, PLoS ONE, vol.11, 2016. ,
Image Recognition of Four Different Alfalfa Leaf Diseases Based on Deep Learning and Support Vector Machine (in Chinese), J. China Agric. Univ, vol.22, pp.123-133, 2017. ,
Construction of Tilletia Diseases Diagnosis System (in Chinese), Plant Quarantine, vol.28, pp.10-15, 2014. ,
Detection of Palm Oil Leaf Disease with Image Processing and Neural Network Classification on Mobile Device, Int. J. Comput. Theor. Eng, vol.5, pp.528-532, 2013. ,
Plant Leaf Image Disease Detection Based on Android (in Chinese), J. Zhengzhou Univ. Light Ind. (Nat. Sci. Ed.), vol.29, pp.71-74, 2014. ,
Design of Apple Leaf Disease Recognition System Based on Android (in Chinese), J. Agric. Univ. Hebei, vol.38, pp.102-106, 2015. ,
