Quantitative remote sensing and its application in agriculture, 2008. ,
Remote sensing for crop management, Photogramm. Eng. Remote Sens, vol.69, pp.647-664, 2003. ,
Empirical regression models for estimating multiyear leaf area index of rice from several vegetation indices at the field scale. Remote Sens, vol.6, pp.4764-4779, 2014. ,
Two separate periods of the LAI-VIs relationships using in situ measurements in a deciduous broadleaf forest, Agric. For. Meteorol, vol.169, pp.148-155, 2013. ,
Spectral estimation of radiation absorptance and leaf area index in corn canopies as affected by canopy architecture and growth stage, Jpn. J. Crop Sci, vol.60, pp.578-580, 1991. ,
Evaluating hyperspectral vegetation indices for estimating nitrogen concentration of winter wheat at different growth stages, Precis. Agric, vol.11, pp.335-357, 2010. ,
Comparative Study on Remote Sensing Invertion Methods for Estimating Winter Wheat Leaf Area Index, Spectroscopy and Spectral Analysis, vol.34, pp.489-493, 2014. ,
Wheat leaf area index inversion with hyperspectral remote sensing based on support vector regression algorithm, Transactions of the Chinese Society of Agricultural Engineering, vol.29, pp.139-146, 2013. ,
Chlorophyll content inversion with hyperspectral technology for wheat canopy based on support vector regression algorithm, Transactions of the Chinese Society of Agricultural Engineering, vol.28, pp.162-171, 2012. ,
Estimation of Winter Wheat Leaf Area Index with Joint Principal Component Analysis and Least Squares Support Vector Model, J]. Journal of Triticeae Crops, vol.34, issue.9, pp.1292-1296, 2014. ,
Hyperspectral Estimation of Leaf Water Content for Winter Wheat Based on Grey Relational Analysis, TSpectroscopy and Spectral Analysis, vol.32, pp.103-3106, 2012. ,
Estimation of Leaf Water Content in Winter Wheat Using Grey Relational Analysis -Partial Least Squares Modeling with Hyperspectral Data, Agronomy Journal, vol.105, issue.5, pp.1085-1392, 2013. ,
Comparison of two inversion methods for winter wheat leaf area index based on hyperspectral remote sensing, Transactions of the Chinese Society of Agricultural Engineering, vol.29, pp.139-147, 2013. ,
Hyperspectral versus multispectral data for estimating leaf area index in four different biomes, Remote Sensing of Environment, vol.91, pp.508-520, 2004. ,
AIC principle and its Application in the Polynomial Models of the Crop Yield ,
, , vol.1, pp.73-78, 1985.
Remote Sensing Prediction of Winter Wheat Protein Content Based on Nitrogen Translocation and GRA-PLS Method ,
, Scientia Agricultura Sinica, vol.47, issue.19, pp.3780-3790, 2014.
Problem of control and information, Proc.2nd Int.Symp.on Information Theory, pp.267-281, 1973. ,
Monitoring the Vernal Advancement and Retrogradation (greenwave effect) of Natural Vegetation, 1974. ,
Remote mapping of standing crop biomass for estimation of the productivity of the shortgrass prairie, Proceedingsof the English International Sysposium on Remote Sensing of Environment, vol.2, pp.1375-1381, 1972. ,
Optimization of soil-adjusted vegetation indices ,
, Remote Sensing environment, vol.55, issue.2, pp.95-107, 1996.
Integrated narrow-band vegetation indices for prediction of crop chlorophyll content for application to precision agriculture ,
, Remote Sensing of Environment, vol.81, issue.2/3, pp.416-426, 2002.
Relationships between leaf pigment content and spectral reflectance across a wide range of species, leaf structures and developmental stages ,
, Remote Sensing of Environment, vol.81, issue.2, pp.337-354, 2002.
Spectral reflectance changes associated with autumn senescence of aesculus Hippocastanum L. and Acer Platanoides L. leaves. spectral features and relation to chlorophyll estimation, J]. Journal of Plant Physiology, vol.143, issue.3, pp.286-292, 1994. ,
Red edge spectral measurements from sugar maple leaves, International Journal of Remote Sensing, vol.14, issue.8, pp.1563-1575, 1993. ,
Semi-empirical indices to assess carotenoids/chlorophyll a ratio from leaf spectral reflectance, Photosynthetica, vol.31, issue.2, pp.221-230, 1995. ,
A narrow-waveband spectral index that tracks diurnal changes in photosynthetic efficienc ,
, Remote Sensing of Environment, vol.41, issue.1, pp.35-44, 1992.
Hyperspectral vegetation indices and novel algorithms for predicting green LAI of crop canopies: modeling and validation in the context of precision agriculture, Remote Sens. Environ, vol.90, pp.337-352, 2004. ,
A Modified Soil Adjusted Vegetation Index. Remote Sensing of Environment, vol.48, pp.119-126, 1994. ,
Evaluation of vegetation indices and modified simple ratio for boreal applications, Can. J. Remote Sens, vol.22, pp.229-242, 1996. ,
