Research on Intelligent Decision of Pulmonary Tuberculosis Disease Based on Data Mining - Archive ouverte HAL Access content directly
Conference Papers Year : 2019
(1) , (1) , (1)
1
Aiming at the problem that the low diagnostic efficiency and low accuracy of the single data mining method for Diagnosis of pulmonary tuberculosis, In this study, the electronic records of 1203 cases of tuberculosis patients in Changping District City, Beijing City of Beijng and Beijing Institute of tuberculosis control and tuberculosis control were build, Tuberculosis disease diagnosis model is built by application of rough set and decision tree method, On the basis of this, the diagnosis system of pulmonary tuberculosis was constructed. In this study, the combining method of rough set and decision tree was approached to attribute reduction, the model reduced redundant 57 attributes and remained 22 attributes, and articled 7 the decision rules. The model accuracy is 89.46%. Compared with the non reduction method, the decision rule was reduced by 128%, and the accuracy of the model remained unchanged. The research results showed that the algorithm can reduce the time and space complexity of the algorithm while ensuring the accuracy of the model, so as to improve the efficiency of the mining, and provide some references for clinical diagnosis.
478221_1_En_43_Chapter.pdf (287.64 Ko) Télécharger le fichier
Dates and versions
hal-02180005 , version 1 (12-07-2019)
Attribution - CC BY 4.0
Identifiers
Cite
Guifen Chen, Wang Ke, Ma Li. Research on Intelligent Decision of Pulmonary Tuberculosis Disease Based on Data Mining. 10th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2016, Dongying, China. pp.425-434, ⟨10.1007/978-3-030-06155-5_43⟩. ⟨hal-02180005⟩
52 View
9 Download
Share
