Field performance of proposed foresight tillage depth control system for rotary implements mounted on an agricultural tractor, J]. Journal of Terramechanics, vol.37, issue.2, pp.99-111, 2000. ,
An automatic depth control system for real time measurement of spatial variation in soil compaction, part 1: sensor design for measurement of frame height variation from soil surface, Biosystems Engineering, vol.89, issue.2, pp.139-150, 2004. ,
Design of the automatic control of the plowing depth of the integrated plowing set, J]. Journal of Agricultural Mechanization Research, issue.9, pp.77-79, 2007. ,
Design researches on tiling depth electron testing system, Journal of Shihezi University: Natural Science, vol.5, issue.3, pp.246-248, 2001. ,
Computerized instrumentation system for monitoring the tractor performance in the field, J]. Journal of Terramechanics, vol.48, issue.5, pp.333-338, 2011. ,
Three-point hitch-mechanism instrumentation for tillage power optimization ,
, Biosystems Engineering, vol.100, issue.1, pp.24-30, 2008.
Design and experiment on the control system of electro-hydraulic plow depth of tractor hydraulic hitch mechanism, Transactions of the Chinese Society for Agricultural Machinery, vol.39, pp.62-65, 2008. ,
Design of a laser land leveler for paddy field ,
, Transactions of the Chinese Society of Agricultural Engineering, vol.23, issue.4, pp.88-93, 2007.
Mapping system for tractor-implement performance Computers and Electronics in Agriculture, vol.69, pp.2-11, 2009. ,
Measuring tillage depth for tractor implement automatic using inclinometer, Transactions of the Chinese Society of Agricultural Engineering, vol.29, pp.15-21, 2013. ,
Development of on-line measurement system of bulk density based on on-line measured draught, depth and soil moisture content. Soil and Tillage Research, vol.86, pp.218-229, 2006. ,
Development and application of an agricultural BUS for data transfer. Computers and Electronics in Agriculture, vol.23, pp.219-237, 1999. ,
Integrated control of agricultural tractors and implements: a review of potential opportunities relating to cultivation and crop establishment machinery. Computers and Electronics in Agriculture, vol.30, pp.167-191, 2001. ,
Field performance of proposed foresight tillage depth control system for rotary implements mounted on an agricultural tractor, Journal of Terramechanics, vol.37, issue.2, pp.99-111, 2000. ,
, Tractors and Machinery for Agriculture and Forestry-Serial Control and Communications Data Network-VirtualTerminal, pp.11783-11789
