Formal Concept Analysis for Identifying Biclusters with Coherent Sign Changes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2019
Nyoman Juniarta
Miguel Couceiro
Amedeo Napoli
In this paper we are studying the task of finding coherent-sign-changes biclusters in a binary matrix. This task can be applied to the interpretation of gene expression data, where such a bicluster represents a set of experiments that affect a set of genes in a consistent way. We start with a binary table and study biclustering methods based on FCA and partition pattern structures. Pattern concepts provide biclusters and their hierarchical relation, which can be used to analyze the profile of genes in the given expression data. Our approach is purely symbolic, so we can detect larger biclusters and work with rather complex data.
nj_sfc19.pdf (136.53 Ko) Télécharger le fichier
hal-02181600 , version 1 (12-07-2019)
  • HAL Id : hal-02181600 , version 1
Nyoman Juniarta, Miguel Couceiro, Amedeo Napoli. Formal Concept Analysis for Identifying Biclusters with Coherent Sign Changes. 2019. ⟨hal-02181600⟩
62 Consultations
103 Téléchargements
