Towards Portable Online Prediction of Network Utilization using MPI-level Monitoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Stealing network bandwidth helps a variety of HPC runtimes and services to run additional operations in the background without negatively affecting the applications. A key ingredient to make this possible is an accurate prediction of the future network utilization, enabling the runtime to plan the background operations in advance, such as to avoid competing with the application for network bandwidth. In this paper, we propose a portable deep learning predictor that only uses the information available through MPI introspection to construct a recurrent sequence-to-sequence neural network capable of forecasting network utilization. We leverage the fact that most HPC applications exhibit periodic behaviors to enable predictions far into the future (at least the length of a period). Our on-line approach does not have an initial training phase, it continuously improves itself during application execution without incurring significant computational overhead. Experimental results show better accuracy and lower computational overhead compared with the state-of-the-art on two representative applications.
paper.pdf (442.65 Ko) Télécharger le fichier
hal-02184204 , version 1 (15-07-2019)
  • HAL Id : hal-02184204 , version 1
Shu-Mei Tseng, Bogdan Nicolae, George Bosilca, Emmanuel Jeannot, Aparna Chandramowlishwaran, et al.. Towards Portable Online Prediction of Network Utilization using MPI-level Monitoring. EuroPar'19: 25th International European Conference on Parallel and Distributed Systems, Aug 2019, Goettingen, Germany. ⟨hal-02184204⟩
151 Consultations
225 Téléchargements
