Partially Asynchronous Distributed Unmixing of Hyperspectral Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Geoscience and Remote Sensing Année : 2019
So far, the problem of unmixing large or multitem- poral hyperspectral data sets has been specifically addressed in the remote sensing literature only by a few dedicated strategies. Among them, some attempts have been made within a distributed estimation framework, in particular, relying on the alternating direction method of multipliers. In this paper, we propose to study the interest of a partially asynchronous distributed unmixing procedure based on a recently proposed asynchronous algorithm. Under standard assumptions, the proposed algorithm inherits its convergence properties from recent contributions in nonconvex optimization, while allowing the problem of interest to be effi- ciently addressed. Comparisons with a distributed synchronous counterpart of the proposed unmixing procedure allow its interest to be assessed on synthetic and real data. Besides, thanks to its genericity and flexibility, the procedure investigated in this paper can be implemented to address various matrix factorization problems.
Thouvenin_24135.pdf (5.3 Mo) Télécharger le fichier
hal-02186067 , version 1 (17-07-2019)
Pierre-Antoine Thouvenin, Nicolas Dobigeon, Jean-Yves Tourneret. Partially Asynchronous Distributed Unmixing of Hyperspectral Images. IEEE Transactions on Geoscience and Remote Sensing, 2019, 57 (4), pp.2009-2021. ⟨10.1109/TGRS.2018.2870486⟩. ⟨hal-02186067⟩
11 Consultations
6 Téléchargements
