Closed-loop control of a spatially developing free shear flow around a steady state, 20 th IFAC World Congress, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01514361
Skin-friction drag reduction via robust reducedorder linear feedback control, International Journal of Computational Fluid Dynamics, vol.11, pp.79-92, 1998. ,
State-space formulation and controller design for three-dimensional channel flows, Proceedings of the 1999 American Control Conference, 1999. ,
A linear systems approach to flow control, Annual Review of Fluid Mechanics, vol.39, pp.383-417, 2007. ,
Input-output measures for model reduction and closedloop control : application to global modes, Journal of Fluid Mechanics, vol.685, pp.23-53, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00997981
Methods of linear control theory, Machine Learning Control -Taming Nonlinear Dynamics and Turbulence, pp.49-68, 2017. ,
Control and system identification of a separated flow, Physics of Fluids, vol.20, issue.10, p.101509, 2008. ,
Streakline-based closed-loop control of a bluff body flow, Physics of Fluids, vol.26, issue.4, 2014. ,
A physics-based approach to flow control using system identification, J. Fluid Mech, vol.702, pp.26-58, 2012. ,
Commande des systèmes : conception, identification et mise en oevre, 2002. ,
Improving robust stability by increasing the number of controlled degrees of freedom, 7th AIAA Flow Control Conference, 2014. ,
URL : https://hal.archives-ouvertes.fr/hal-01101089
Fluid flow control : a vision-based approach, Int. Journal of Flow Control, vol.3, issue.2, pp.133-169, 2011. ,
URL : https://hal.archives-ouvertes.fr/hal-00701080
A system theory approach to the feedback stabilization of infinitesimal and finite amplitude disturbances in plane Poiseuille flow, J. Fluid Mech, vol.332, pp.157-184, 1997. ,
Accommodation of external disturbances in linear regulator and servomechanism problem, IEEE Transactions on Automatic Control, vol.16, issue.5, pp.635-644, 1971. ,
Adaptive Control : Stability, Convergence, and Robustness, 1994. ,
Nonlinear PID predictive controller, IEE Proc-Control Theory Appl, vol.146, issue.6, pp.603-611, 1999. ,
Smooth stabilization implies coprime factorization, IEEE Trans. on Automatic Control, vol.34, issue.4, pp.435-443, 1989. ,
High-order compact schemes for incompressible flows : A simple and efficient method with quasi-spectral accuracy, J. Comput. Phys, vol.228, issue.16, pp.5989-6015, 2009. ,
URL : https://hal.archives-ouvertes.fr/hal-00459942
