Perceptual proxies for extracting averages in data visualizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Psychonomic Bulletin and Review Année : 2019
Steve Haroz
Steven Franconeri
  • Fonction : Auteur
  • PersonId : 959089
Across science, education, and business, we process and communicate data visually. One bedrock finding in data visualization research is a hierarchy of precision for perceptual encodings of data, e.g., that encoding data with Cartesian positions allows more precise comparisons than encoding with sizes. But his hierarchy has only been tested for single value comparisons, under the assumption that those lessons would extrapolate to multi-value comparisons. We show that when comparing averages across multiple data points, even for pairs of data points, these differences vanish. Viewers instead compare values using surprisingly primitive perceptual cues, e.g., the summed area of bars in a bar graph. These results highlight a critical need to study a broader constellation of visual cues that mediate the patterns that we can see in data, across visualization types and tasks.
_manuscript.pdf (903.64 Ko) Télécharger le fichier
hal-02189581 , version 1 (19-07-2019)
Lei Yuan, Steve Haroz, Steven Franconeri. Perceptual proxies for extracting averages in data visualizations. Psychonomic Bulletin and Review, 2019, 26 (2), pp.669-676. ⟨10.3758/s13423-018-1525-7⟩. ⟨hal-02189581⟩
200 Consultations
160 Téléchargements
