A Transparent Display with Per-Pixel Color and Opacity Control - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
T J Rhodes
  • Fonction : Auteur
Gavin Miller
  • Fonction : Auteur
Qi Sun
  • Fonction : Auteur
Daichi Ito
  • Fonction : Auteur
Li-Yi Wei
  • Fonction : Auteur
We propose a new display system that composites matted foreground animated graphics and video, with per-pixel controllable emitted color and transparency, over real-world dynamic objects seen through a transparent display. Multiple users can participate simultaneously without any glasses, trackers, or additional devices. The current prototype is deployed as a desktop-monitor-sized transparent display box assembled from commodity hardware components with the addition of a high-frame-rate controllable diffuser.
sig19.pdf (3.85 Mo) Télécharger le fichier
hal-02189965 , version 1 (20-07-2019)
hal-02189965 , version 2 (27-07-2019)
hal-02189965 , version 3 (05-08-2019)
T J Rhodes, Gavin Miller, Qi Sun, Daichi Ito, Li-Yi Wei. A Transparent Display with Per-Pixel Color and Opacity Control. SIGGRAPH 2019 Emerging Technologies, Aug 2019, Los Angeles, United States. ⟨10.1145/3305367.3327984⟩. ⟨hal-02189965v1⟩
195 Consultations
233 Téléchargements
