MUSDB18 - a corpus for music separation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2017
The sigsep musdb18 data set consists of a total of 150 full-track songs of different styles and includes both the stereo mixtures and the original sources, divided between a training subset and a test subset. Its purpose is to serve as a reference database for the design and the evaluation of source separation algorithms. The objective of such signal processing methods is to estimate one or more sources from a set of mixtures, e.g. for karaoke applications. It has been used as the official dataset in the professionally-produced music recordings task for SiSEC 2018, which is the international campaign for the evaluation of source separation algorithms.
Mots clés
musdb.pdf (141.8 Ko) Télécharger le fichier
hal-02190845 , version 1 (30-07-2019)
Copyright (Tous droits réservés)
Zafar Rafii, Antoine Liutkus, Fabian-Robert Stöter, Stylianos Ioannis Mimilakis, Rachel Bittner. MUSDB18 - a corpus for music separation. 2017, ⟨10.5281/zenodo.1117371⟩. ⟨hal-02190845⟩
1160 Consultations
1200 Téléchargements
