On the implementation and consequences of the oceanic currents feedback in ocean-atmosphere coupled models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Ocean Modelling Année : 2019
The Current FeedBack (CFB) to the atmosphere simply represents the influence of the surface oceanic currents on near-surface wind and surface stress. As the CFB has a significant influence on the oceanic circulation, it is crucial to implement it properly in a coupled Ocean-Atmosphere model. In this study, we first detail the modifications to be implemented into atmospheric models to account for the CFB. In the computation of air-sea fluxes, the relative winds, i.e., the difference between the near-surface winds and the surface oceanic currents, instead of absolute winds have to be used (Modification M1). However, because of the implicit treatment of the bottom boundary condition in most atmospheric models, the use of relative winds also involves a modification of the tridiagonal problem associated with the discretization of the vertical turbulent viscosity (Modification M2). Secondly, we show both analytically and using global coupled simulations that omitting M2 leads to a large underestimation of the surface stress curl response to the CFB and, subsequently, of the coupling coefficient between mesoscale surface stress curl and surface current vorticity. As a consequence, the dampening of the mesoscale activity induced by the CFB is strongly reduced (by a minimum a factor of 2 or more). The practical implementation of the CFB must be done carefully in the atmospheric component of a coupled model in order to avoid a large underestimation of the CFB effect on the oceanic circulation.
Renault_etal_omod_2019.pdf (1.84 Mo) Télécharger le fichier
hal-02190847 , version 1 (23-07-2019)
Lionel Renault, Florian Lemarié, Thomas Arsouze. On the implementation and consequences of the oceanic currents feedback in ocean-atmosphere coupled models. Ocean Modelling, 2019, 141, pp.101423. ⟨10.1016/j.ocemod.2019.101423⟩. ⟨hal-02190847⟩
171 Consultations
501 Téléchargements
