, European Commission: Challenging and Changing Europe's Built Environment A vision for a sustainable and competitive construction sector by 2030, 2005.
Building Information Modeling -BIM: Contractual Risks are Changing with Technology, 2010. ,
Engaging construction stakeholders with sustainability through a knowledge harvesting platform, Comput. Ind, vol.65, pp.449-469, 2014. ,
BIM implementation throughout the UK construction project lifecycle: An analysis, Autom. Constr, vol.36, pp.145-151, 2013. ,
Global Construction Outlook: Executive Outlook, 2013. ,
Optimizing Energy Efficiency in Operating Built Environment Assets through Building Information Modeling: A Case Study, Energies, vol.10, p.1167, 2017. ,
, Global Construction Perspectives and Oxford Economics: Global Construction 2030 A global forecast for the construction industry to 2030, 2015.
Multiobjective optimization of building design using TRNSYS simulations, genetic algorithm, and Artificial Neural Network, Build. Environ, vol.45, pp.739-746, 2010. ,
Optimization of distributed generation capacities in buildings under uncertainty in load demand, Energy Build, vol.57, pp.58-64, 2013. ,
Harvesting and Managing Knowledge in Construction: From Theoretical Foundations to Business Applications, Routledge, 2011. ,
The project benefits of Building Information Modelling (BIM), Int. J. Proj. Manag, vol.31, pp.971-980, 2013. ,
An ANN-GA Semantic Rule-Based System to Reduce the Gap Between Predicted and Actual Energy Consumption in Buildings, IEEE Trans. Autom. Sci. Eng, vol.14, pp.1351-1363, 2017. ,
BIM-based parametric building energy performance multi-objective optimization, 2014. ,
