A Framework to Support Industry 4.0: Chemical Company Case Study - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2018
Arturo Ortega
  • Fonction : Auteur
  • PersonId : 1051248
Belén Falcón
  • Fonction : Auteur
  • PersonId : 1051249
Leopoldo Mitre
  • Fonction : Auteur
  • PersonId : 1051250
Rodrigo Correa
  • Fonction : Auteur
  • PersonId : 1051251
Jaime Moreno
  • Fonction : Auteur
  • PersonId : 1051252
Rafael Funes
  • Fonction : Auteur
  • PersonId : 1051253
The concept of Industry 4.0 corresponds to a new way of organizing the production of goods, taking smarter decisions based on environmental variables and optimizing available resources. However, there is still a journey to carry out the implementation of this concept with current technologies. To make this transformation of the industry, it is necessary to characterize the Industry 4.0 concept, adopt a strategic thinking, and acquire skills, aptitudes, and attitudes. Enterprise reference models can help in orchestrating the change, however, the relationship between existing reference models and Industry 4.0 needs further clarification. Thus, this paper proposes a framework that links a reference model with the Industry 4.0 concept. Furthermore, a tool for the instantiation of the framework is proposed to provide practical approach. And the results of implementing the proposed framework are presented in a case study.
472393_1_En_33_Chapter.pdf (579.62 Ko) Télécharger le fichier
hal-02191185 , version 1 (24-07-2019)
Paternité
Daniel Cortés Serrano, Dante Chavarría-Barrientos, Arturo Ortega, Belén Falcón, Leopoldo Mitre, et al.. A Framework to Support Industry 4.0: Chemical Company Case Study. 19th Working Conference on Virtual Enterprises (PRO-VE), Sep 2018, Cardiff, United Kingdom. pp.387-395, ⟨10.1007/978-3-319-99127-6_33⟩. ⟨hal-02191185⟩
89 Consultations
68 Téléchargements
