Theory Combination: Beyond Equality Sharing
Satisfiability is the problem of deciding whether a formula has a model. Although it is not even semidecidable in first-order logic, it is decidable in some first-order theories or fragments thereof (e.g., the quantifier-free fragment). Satisfiability modulo a theory is the problem of determining whether a quantifier-free formula admits a model that is a model of a given theory. If the formula mixes theories, the considered theory is their union, and combination of theories is the problem of combining decision procedures for the individual theories to get one for their union. A standard solution is the equality-sharing method by Nelson and Oppen, which requires the theories to be disjoint and stably infinite. This paper surveys selected approaches to the problem of reasoning in the union of disjoint theories, that aim at going beyond equality sharing, including: asymmetric extensions of equality sharing, where some theories are unrestricted, while others must satisfy stronger requirements than stable infiniteness; superposition-based decision procedures; and current work on conflict-driven satisfiability (CDSAT).
