Relational Recurrent Neural Networks For Vehicle Trajectory Prediction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Scene understanding and future motion prediction of surrounding vehicles are crucial to achieve safe and reliable decision-making and motion planning for autonomous driving in a highway environment. This is a challenging task considering the correlation between the drivers behaviors. Knowing the performance of Long Short Term Memories (LSTMs) in sequence modeling and the power of attention mechanism to capture long range dependencies, we bring relational recurrent neural networks (RRNNs) to tackle the vehicle motion prediction problem. We propose an RRNNs based encoder-decoder architecture where the encoder analyzes the patterns underlying in the past trajectories and the decoder generates the future trajectory sequence. The originality of this network is that it combines the advantages of the LSTM blocks in representing the temporal evolution of trajectories and the attention mechanism to model the relative interactions between vehicles. This paper compares the proposed approach with the LSTM encoder decoder using the new large scaled naturalistic driving highD dataset. The proposed method outperforms LSTM encoder decoder in terms of RMSE values of the predicted trajectories. It outputs an estimate of future trajectories over 5s time horizon for longitudinal and lateral prediction RMSE of about 3.34m and 0.48m, respectively.
RRNN_ITSC.pdf (365.68 Ko) Télécharger le fichier
hal-02195180 , version 1 (05-08-2019)
Kaouther Messaoud, Itheri Yahiaoui, Anne Verroust-Blondet, Fawzi Nashashibi. Relational Recurrent Neural Networks For Vehicle Trajectory Prediction. Intelligent Transportation Systems Conference (ITSC), Oct 2019, Auckland, New Zealand. ⟨10.1109/ITSC.2019.8916887⟩. ⟨hal-02195180⟩
233 Consultations
1191 Téléchargements
