Sampling Representation Contexts with Attribute Exploration
We tackle the problem of constructing the representation context of a pattern structure. First, we present a naive algorithm that computes the representation context of a pattern structure. Then, we add a sampling technique in order to reduce the size of the output. We show that these techniques reduce significantly the size of the representation context for interval pattern structures.
Intelligence artificielle [cs.AI]
