, Linear Regression Analysis: Theory and Computing, 2009.
, ser. Wiley Series in Probability and Statistics, vol.709, 2012.
Adaptive Systems with Reduced Models, 1983. ,
System Identification: Theory for the User, 1987. ,
, Adaptive Control: Stability, Convergence and Robustness, 1989.
, Nonlinear Systems, 2002.
Persistent excitation in adaptive systems, International Journal of Control, vol.45, issue.1, pp.127-160, 1987. ,
Design of impulsive adaptive observers for improvement of persistency of excitation, Int. J. Adaptive Control and Signal Processing, vol.29, issue.6, pp.765-782, 2015. ,
URL : https://hal.archives-ouvertes.fr/hal-01016332
Convergence of the gradient algorithm for linear regression models in the continuous and discrete time cases, 2016. ,
URL : https://hal.archives-ouvertes.fr/hal-01423048
On global asymptotic stability of? = ??(t)? (t)x with ?(t) bounded and not persistently exciting, Systems & Control Letters, vol.109, pp.24-27, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01816386
Robust stability under relaxed persistent excitation conditions, International Journal of Adaptive Control and Signal Processing, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01888575
Concurrent learning adaptive control of linear systems with exponentially convergent bounds, International Journal of Adaptive Control and Signal Processing, vol.27, issue.4, pp.280-301, 2012. ,
Model-based reinforcement learning for approximate optimal regulation, Automatica, vol.64, pp.94-104, 2016. ,
On robust parameter estimation in finite-time without persistence of excitation, IEEE Transactions on Automatic Control, 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01998043
Enhanced parameter convergence for linear systems identification: The DREM approach, Proc. European Control Conference (ECC), 2018. ,
URL : https://hal.archives-ouvertes.fr/hal-01981080
Homogeneous Approximation, Recursive Observer Design, and Output Feedback, SIAM J. Control Optimization, vol.47, issue.4, pp.1814-1850, 2008. ,
URL : https://hal.archives-ouvertes.fr/hal-00362707
Uniform robust exact differentiator, IEEE Transactions on Automatic Control, vol.56, issue.11, pp.2727-2733, 2011. ,
Nonlinear feedback design for fixed-time stabilization of linear control systems, IEEE Transactions on Automatic Control, vol.57, issue.8, pp.2106-2110, 2012. ,
URL : https://hal.archives-ouvertes.fr/hal-00757561
Time-varying feedback for regulation of normal-form nonlinear systems in prescribed finite time, Automatica, vol.83, pp.243-251, 2017. ,
Finite-time parameter estimation without persistence of excitation, Proc. European Control Conference, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-02084983
Performance enhancement of parameter estimators via dynamic regressor extension and mixing, IEEE Transactions on Automatic Control, vol.62, issue.7, pp.3546-3550, 2017. ,
URL : https://hal.archives-ouvertes.fr/hal-01612256
A continuous-time observer which converges in finite time, IEEE Transactions on Automatic Control, vol.47, issue.7, pp.1202-1204, 2002. ,
Homogeneous time-varying systems: Robustness analysis, IEEE Transactions on Automatic Control, vol.61, issue.12, pp.4075-4080, 2016. ,
On stability of motion over a finite interval of time, Journal of Applied Math. and Mechanics (PMM), vol.17, pp.529-540, 1953. ,
The problem of stability in a finite interval of time, Journal of Applied Math. and Mechanics (PMM), vol.18, pp.75-94, 1954. ,
Short-time stability in linear time-varying systems, 1961. ,
On the stability of systems defined over a finite time interval, Proc. of the National Academy of Sciences, vol.54, pp.440-448, 1965. ,
On finite stability in control systems, Rendiconti del Circolo Matematico di Palermo, vol.15, pp.273-283, 1966. ,
Geometric homogeneity with applications to finite-time stability, Mathematics of Control, Signals and Systems, vol.17, pp.101-127, 2005. ,
H? control, stabilization, and input-output stability of nonlinear systems with homogeneous properties, Automatica, vol.37, issue.7, pp.819-829, 2001. ,
Verification of ISS, iISS and IOSS properties applying weighted homogeneity, Systems & Control Letters, vol.62, pp.1159-1167, 2013. ,
URL : https://hal.archives-ouvertes.fr/hal-00877148
Gramian-based uniform convergent observer for stable LTV systems with delayed measurements, Int. J. Control, 2019. ,
URL : https://hal.archives-ouvertes.fr/hal-01889193
The Theory of Matrices, 1960. ,
Time-varying parameter identification algorithms: Finite and fixed-time convergence, IEEE Transactions on Automatic Control, vol.62, issue.7, pp.3671-3678, 2017. ,
An adaptive sliding-mode observer for a class of uncertain nonlinear systems, International Journal of Adaptive Control and Signal Processing, vol.32, issue.3, pp.511-527, 2018. ,
On characterizations of the input-to-state stability property, Systems & Control Letters, vol.24, pp.351-359, 1995. ,
