Exact and efficient computations on circles in CGAL - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Pedro M. M. de Castro
  • Fonction : Auteur
  • PersonId : 855158
Sylvain Pion
Monique Teillaud
CGAL (Computational Geometry Algorithms Library) is a large collection of geometric objects, data structures and algorithms. CGAL currently offers functionalities mostly for linear objects (points, segments, lines, triangles...). The first version of a kernel for circles and circular arcs in 2D was recently released in CGAL 3.2. We show in this paper a variety of techniques that we tested to improve the efficiency of the 2D circular kernel. These improvements are motivated by applications to VLSI design, and real VLSI industrial data are used to measure the impact of the techniques used to enhance this kernel. The improvements will be integrated in CGAL 3.3.
teillaud.pdf (380.08 Ko) Télécharger le fichier
vignette.pdf (111.79 Ko) Télécharger le fichier
Format : Figure, Image
hal-02196933 , version 1 (29-07-2019)
  • HAL Id : hal-02196933 , version 1
Pedro M. M. de Castro, Sylvain Pion, Monique Teillaud. Exact and efficient computations on circles in CGAL. 23rd European Workshop on Computational Geometry, 2007, Graz, Austria. ⟨hal-02196933⟩
Collections
INRIA INRIA2
24 Consultations
109 Téléchargements
