, Computational Geometry Algorithms Library
Arrangements and their applications, Handbook of Computational Geometry, pp.49-119, 2000. ,
Navigating C++ and Object-Oriented Design, 2003. ,
Generic Programming and the STL, 1998. ,
Interval arithmetic yields efficient dynamic filters for computational geometry, Discrete Applied Mathematics, vol.109, pp.25-47, 2001. ,
A method for overlapping and erasure of lists, Communications of the ACM, vol.3, issue.12, pp.655-657, 1960. ,
Algebraic methods and arithmetic filtering for exact predicates on circle arcs, Comput. Geom. Theory Appl, vol.22, pp.119-142, 2002. ,
URL : https://hal.archives-ouvertes.fr/inria-00072832
Computing with real algebraic numbers of small degree, Proc. 12th European Symposium on Algorithms, vol.3221, pp.652-663, 2004. ,
Towards an open curved kernel, Proc. 20th Annu. ACM Sympos, pp.438-446, 2004. ,
Monique Teillaud, Ron Wein, and Nicola Wolpert. Arrangements, Effective Computational Geometry for Curves and Surfaces, 2006. ,
Generic programming and the CGAL library, Effective Computational Geometry for Curves and Surfaces, 2006. ,
URL : https://hal.archives-ouvertes.fr/hal-01053388
2D regularized boolean set-operations, 2006. ,
Look: A lazy objectoriented kernel for geometric computation, Proc. 16th ,
, Annu. ACM Sympos. Comput. Geom, pp.156-165, 2000.
, Handbook of Discrete and Computational Geometry, chapter 21, pp.389-412, 1997.
Sylvain Pion, and Michael Seel. An adaptable and extensible geometry kernel, Computational Geometry: Theory and Applications ,
Root comparison techniques applied to computing the additively weighted Voronoi diagram, Proc. 14th ACM-SIAM Sympos. Discrete Algorithms (SODA), pp.320-329, 2003. ,
ESOLID -a system for exact boundary evaluation, Computer-Aided Design, vol.26, issue.2, pp.175-193, 2004. ,
Traits: a new and useful template technique, 1995. ,
2D circular kernel, 2006. ,
Baruch Zukerman, and Dan Halperin. 2D arrangements, 2006. ,
Advanced programming techniques applied to CGAL's arrangement package. Computational Geometry: Theory and Applications, To appear, Special issue on CGAL ,
The exact computation paradigm, Computing in Euclidean Geometry, vol.4, pp.452-492, 1995. ,
