HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Journal articles
On robust parameter estimation in finite-time without persistence of excitation
Abstract : The problem of adaptive estimation of constant parameters in the linear regressor model is studied without the hypothesis that regressor is Persistently Excited (PE). First, the initial vector estimation problem is transformed to a series of the scalar ones using the method of Dynamic Regressor Extension and Mixing (DREM). Second, several adaptive estimation algorithms are proposed for the scalar scenario. In such a case, if the regressor may be nullified asymptotically or in a finite time, then the problem of estimation is also posed on a finite interval of time. Robustness of the proposed algorithms with respect to measurement noise and exogenous disturbances is analyzed. The efficiency of the designed estimators is demonstrated in numeric experiments for academic examples.
Document type :
Journal articles
Complete list of metadata
Cited literature [32 references]  Display  Hide  Download
https://hal.inria.fr/hal-02196992
Contributor : Denis Efimov Connect in order to contact the contributor
Submitted on : Monday, July 29, 2019 - 6:55:05 PM
Last modification on : Thursday, March 24, 2022 - 3:43:43 AM
File
FT_Adaptive_J.pdf
Identifiers
Citation
Jian Wang, Denis Efimov, Alexey Bobtsov. On robust parameter estimation in finite-time without persistence of excitation. IEEE Transactions on Automatic Control, Institute of Electrical and Electronics Engineers, 2020, 65 (4), pp.1731-1738. ⟨10.1109/TAC.2019.2932960⟩. ⟨hal-02196992⟩
Share
Metrics
Record views
215
Files downloads
232
