Shape optimisation with multiresolution subdivision surfaces and immersed finite elements, Computer Methods in Applied Mechanics and Engineering, vol.300, pp.510-539, 2016. ,
Isogeometric analysis using T-splines, Computer Methods in Applied Mechanics and Engineering, vol.199, issue.5, pp.229-263, 2010. ,
URL : https://hal.archives-ouvertes.fr/hal-01517950
A simple approach to the numerical simulation with trimmed CAD surfaces, Computer Methods in Applied Mechanics and Engineering, vol.285, pp.776-790, 2015. ,
, Geometrically Unfitted Finite Element Methods and Applications, 2017.
A cut finite element method with boundary value correction, Mathematics of Computation, vol.87, pp.633-657, 2018. ,
The moving line ideal basis of planar rational curves, Computer Aided Geometric Design, vol.15, issue.8, pp.803-827, 1998. ,
CutFEM: Discretizing geometry and partial differential equations, International Journal for Numerical Methods in Engineering, vol.104, issue.7, pp.472-501 ,
Adaptive quadrature-revisited, BIT Numerical Mathematics, vol.40, issue.1, pp.84-101, 2000. ,
Discontinuous Galerkin isogeometric analysis of elliptic diffusion problems on segmentations with gaps, SIAM Journal on Scientific Computing, vol.38, issue.6, pp.3430-3460, 2016. ,
Discontinuous Galerkin isogeometric analysis for parametrizations with overlapping regions, 2017. ,
Isogeometric analysis: CAD, finite elements, NURBS, exact geometry and mesh refinement, Computer Methods in Applied Mechanics and Engineering, vol.194, pp.4135-4195, 2005. ,
URL : https://hal.archives-ouvertes.fr/hal-01513346
On numerical integration in isogeometric subdivision methods for PDEs on surfaces, Computer Methods in Applied Mechanics and Engineering, vol.302, pp.131-146, 2016. ,
An immersogeometric variational framework for fluid-structure interaction: Application to bioprosthetic heart valves, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.1005-1053, 2015. ,
Isogeometric analysis for trimmed CAD surfaces, Computer Methods in Applied Mechanics and Engineering, vol.198, pp.2982-2995, 2009. ,
Efficient rendering of trimmed nurbs surfaces, Computer-Aided Design, vol.27, issue.7, pp.509-521, 1995. ,
High order unfitted finite element methods on level set domains using isoparametric mappings, Computer Methods in Applied Mechanics and Engineering, vol.300, pp.716-733, 2016. ,
others (see website): G+Smo (Geometry plus Simulation modules), 2018. ,
Improved conditioning of isogeometric analysis matrices for trimmed geometries, Computer Methods in Applied Mechanics and Engineering, vol.334, pp.79-110, 2018. ,
A review of trimming in isogeometric analysis: Challenges, data exchange and simulation aspects, Archives of Computational Methods in Engineering, pp.1-69, 2017. ,
On the numerical integration of trimmed isogeometric elements, Computer Methods in Applied Mechanics and Engineering, vol.284, pp.165-185, 2015. ,
A survey of the marching cubes algorithm, Computers & Graphics, vol.30, issue.5, pp.854-879, 2006. ,
The NURBS book, 1997. ,
A fixed-grid b-spline finite element technique for fluid-structure interaction, International Journal for Numerical Methods in Fluids, vol.74, issue.9, pp.623-660, 2014. ,
Weak coupling for isogeometric analysis of non-matching and trimmed multi-patch geometries, Computer Methods in Applied Mechanics and Engineering, vol.269, pp.46-71, 2014. ,
Immersed b-spline (i-spline) finite element method for geometrically complex domains, Computer Methods in Applied Mechanics and Engineering, vol.200, issue.13, pp.1432-1445, 2011. ,
Isogeometric analysis of trimmed NURBS geometries, Computer Methods in Applied Mechanics and Engineering, vol.244, pp.93-111, 2012. ,
Partial tensor decomposition for decoupling isogeometric Galerkin discretizations, Computer Methods in Applied Mechanics and Engineering, vol.336, pp.485-506, 2018. ,
Reparameterization and adaptive quadrature for the isogeometric discontinuous Galerkin method, Mathematical Methods for Curves and Surfaces, pp.251-269, 2017. ,
Isogeometric topology optimization using trimmed spline surfaces, Computer Methods in Applied Mechanics and Engineering, vol.199, pp.3270-3296, 2010. ,
Estimation of planar curves, surfaces, and nonplanar space curves defined by implicit equations with applications to edge and range image segmentation, IEEE Transactions on Pattern Analysis and Machine Intelligence, vol.13, issue.11, pp.1115-1138, 1991. ,
An IGA discontinuous Galerkin method on the union of overlapped patches, Computer Methods in Applied Mechanics and Engineering, vol.326, pp.446-480, 2017. ,
Nonconforming isogeometric analysis for trimmed CAD geometries using finite-element tearing and interconnecting algorithm, Proceedings of the Institution of Mechanical Engineers, vol.231, issue.8, pp.1371-1389, 2017. ,
